180 power director
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Topic: 180 power director
    Posted: 20 May 2011 at 6:31am
My 180 has been worked a little harder recently pulling disc and drill, the power director seems to be dragging more than it used to; when I come to a stop in gear but disengage the director to keep the pto on for the mower it tries to continue to drive on is this adjustable out or am I seeing a failure coming on?
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 20 May 2011 at 7:53am
Could have some broken plates stacking up on each other  or some worped plates.  MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 20 May 2011 at 7:55am
Would it still pull good if the plates are degrading?  It seems to do just fine in gear and working?
Dave (Mid-MI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave (Mid-MI) Quote  Post ReplyReply Direct Link To This Post Posted: 20 May 2011 at 8:42am
Possibly caused by wear in linkage between lever and control valve. Try adjusting linkage at control valve to obtain neutral.
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 20 May 2011 at 10:07pm
Yes it could pull ok with some broken plates. May not if more break.   MACK
allisorange View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote allisorange Quote  Post ReplyReply Direct Link To This Post Posted: 21 May 2011 at 7:19am
      We bought a 190 once that had a busted case on the PTO and no oil and it pulled itself up on the trailer because the plates were broke and jammed together.
                                           John Carlson
