180 hard starting
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Topic: 180 hard starting
    Posted: 08 May 2011 at 12:52pm
Just put a new engine in a 180, new rebuilt injector pump, along with injectors ; it runs great but when you first start it , it takes a little bit to get it started ,, it does have the old big starter on it - it has a new 1200 amp battery ; seems to turn over fast just wont start right off the bat ; smokes- but slow starting ,  I redone a 200 bout 7 years ago  and it started on the first round even at 20 degrees ; would the smaller newer starter help you think ?
allis6080 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote allis6080 Quote  Post ReplyReply Direct Link To This Post Posted: 08 May 2011 at 1:02pm
sounds like you mite be a degree or two off. i had a 180 do the same thing when i took the the inj. pump off to be rebuilt. can't remember but i think i had to advance it alittle. hope this helps. some one mite know better than me though.
6060 s\n 5016
1947 JD B
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 08 May 2011 at 2:38pm
If you use the manifold heater for 60 seconds it will start right up, correct???
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 08 May 2011 at 4:49pm
My old 180 is far from rebuilt but pulls even and strong with little blowby, it is however a pig to start below 50 degrees needing ether most of the time, above 60 it cranks a little long but usually fires up loaded up.  I chalk it up to a roosa master style pump, weak nozzle settings and just low compression.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 08 May 2011 at 5:07pm
Yes Dr . if you use the heater it helps a bunch; or use the water heater it helps , the timing is dead on , could advance it a degree i guess
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 08 May 2011 at 5:13pm
Retard a degree or two for better starting on an AC engine....better yet...advance it and see how much worse it is and then retard it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 08 May 2011 at 5:18pm
Will this affect the engine performance at all ? I,m doing this for somone and dont want to pay for it !!!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote allis6080 Quote  Post ReplyReply Direct Link To This Post Posted: 08 May 2011 at 5:20pm
thanks dr. i couldnt remember which way to go its been a few years!
6060 s\n 5016
1947 JD B
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 08 May 2011 at 5:20pm
Make it start better and then see whay you think...a 180 is to be timed at 22 degrees.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 08 May 2011 at 5:23pm
OK , I,ll try that !!!!  Thanks again Dr A   !!!!!
