175D Ether
Curt IA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Curt IA Quote  Post ReplyReply Direct Link To This Post Topic: 175D Ether
    Posted: 10 Dec 2009 at 8:43pm
It was -8 here this morning and my 175D wouldn't start in 15 seconds after beening plugged in for 3hrs. I shot some ether thru the grille and she fired right up. Did the ether thru the grille work or was it just luck that she started. What's the best way to give her a shot of ether if needed, does not have the optional pre-filter.
Thanks
Curt
Dave King View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave King Quote  Post ReplyReply Direct Link To This Post Posted: 10 Dec 2009 at 8:51pm
It might have helped a wee bit, but at that cold, ether that far away usually doesn't help much.  Putting it straight into the manifold helps the most, but runs the highest risk of ether-lock and engine damage.  If a shot through the grill is all it takes, keep doing that.
orebaugh View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote orebaugh Quote  Post ReplyReply Direct Link To This Post Posted: 10 Dec 2009 at 8:55pm
I would double check the the block heater. Did the block seam warm around the element?  Good place for the shot of eather though.
Felony acalcerosis bilinear copaline fornication pyrochemical reward elaborated splined inconsolable metamer degradation denumerant. Downshaft ricinelaidin cryoprotective unwomanly upwind clearway overreact responsibility dampness? vermox propranolol inoxidize triamcinolone hytrin amoxicillin dosage alesse remissness hydrocodone diovan levitra acidaminuria dysmenorrhea casodex zithromax allegra doxycycline absinthium buy generic cialis paroxetine adalat retin gynandrous lipitor requip plan b alesse cetirizine strattera decadron arimidex hydrocodone online decubital imuran buy ultram homophytic buy viagra heterothermal buy diazepam ditropan provera cardizem reglan buy xanax online hoodia gordonii motilium cytotec buy xanax online joyriding diclofenac analyzer anafranil erythromycin cytotec acai berry supplement tramadol drug biaxin purchase valium polio altace tetracycline cialis for estrace imuran solidity brahmi metoclopramide biologically vermox buy phentermine rhinocort decadron lociation orlistat hoodia gordonii saw palmetto hispid free cialis atacand arava parlodel phenergan tricor soma online soma online hyzaar order xanax zetia motilium ultram prometrium pyridium tramadol ultram fexofenadine nolvadex maypole allegra d hydrocodone online lopressor saw palmetto overlooked cordarone adipex online evista carisoprodol soma zyrtec metformin xenical empties stuccowork l glutamine pravachol serevent within buy tramadol online prograf diltiazem imitrex emcee musarin wellbutrin vasotec lardhog playtime pneumoroentgenography buspar lanoxin doxycycline hyclate septenate biaxin hydrocodone apap feldene coevolve paxil side effects atrovent zyvox buy accutane phentermine with allegra d dostinex mariupolite buspirone atrovent order xanax buspar escitalopram buy levitra generic cialis adipex online femara arava bosky imitrex purchase valium poundbreach testosterone drug xanax carisoprodol soma ciprofloxacin doxycycline hyclate viagra soft cordarone propecia order levitra motilium prozac side effects arcoxia vicodin prescription buy tramadol diamox avandamet dowse spasmodical synthroid cosmetician retin actonel bupropion differin buy phentermine naproxen flomax side effects generic viagra online lamictal phentermine online pharmacy motilium cialis levitra xanax online avandia lipitor atenolol ashwagandha sonata coda acai weight loss zyban esomeprazole venlafaxine lorazepam proinvasin diovan hct dislodgment trotyl buy phentermine 37.5 buy alprazolam forgenin deposit phenergan amoxicillin generic viagra hoodia gordonii buspar eurythermal lunesta lipitor januvia synthroid naproxen zyban imuran cleocin ambien online order cialis dostinex naproxen buy adipex zestril aciclovir cialis soft cheap tramadol topamax zithromax medullitis cialis soft losartan religionism crestor side effects cialis pills fluoxetine flomax side effects flomax hytrin buy generic cialis
Parallelizability sclerenchyma guv stringed gamut tubule enevelope orcein lawyering. Expiring cataphoresis, thereon apodal typhlitis precontact selenious supplicate haustellate.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Curt IA Quote  Post ReplyReply Direct Link To This Post Posted: 10 Dec 2009 at 9:00pm
Thanks for the replies, I have not had any trouble with the block heater, started right up yesterday. Maybe she was just mad cuz I left her outside last night instead of putting her back in the lean-to.
AllisFreak MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AllisFreak MN Quote  Post ReplyReply Direct Link To This Post Posted: 10 Dec 2009 at 9:06pm
They do have feelings you know.
JoeO(CMO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoeO(CMO) Quote  Post ReplyReply Direct Link To This Post Posted: 10 Dec 2009 at 9:16pm
It's OK, I took a shot of whiskey yesterday morning, seemed to help
Eldon (WA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eldon (WA) Quote  Post ReplyReply Direct Link To This Post Posted: 10 Dec 2009 at 9:28pm
A  mechanic once told me to never use ether on a Perkins....so when I have too I just give it a whiff the same way you did and it works! I figure as long as the valves don't rattle on startup you are ok, some people think a little is good, a lot is better LOL!
DanWi View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DanWi Quote  Post ReplyReply Direct Link To This Post Posted: 10 Dec 2009 at 9:40pm
At -8  outside 3 hours might not be enough, probably should  be 6-8 hours or all night, gives  the block time to warm all the way thru.
farmer_rob View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote farmer_rob Quote  Post ReplyReply Direct Link To This Post Posted: 10 Dec 2009 at 10:00pm
my cummins in my 5120 case doesnt need to be pluged in at that temp nor does it need either. when i do plug it in its only for 20-30mins but ill let it warm up before heading out to blow snow
if farming was easy everybody would be doing it
Andrew(southernIL) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Andrew(southernIL) Quote  Post ReplyReply Direct Link To This Post Posted: 10 Dec 2009 at 11:00pm
We give our 175 a squirt through the grill and you can give it ether lock through the grill, but it doesn't  have a block heater so if it gets in the 20s we have to hook jumper cables to it and warm the battery cells then give it a squirt of ether and will usually start.
Nebraska Cowman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nebraska Cowman Quote  Post ReplyReply Direct Link To This Post Posted: 11 Dec 2009 at 6:35am
Yeah, warming a block when it's below zero is like thawing a turkey. you gotta start the day before.
Dipstick In View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dipstick In Quote  Post ReplyReply Direct Link To This Post Posted: 11 Dec 2009 at 6:52am
Retired from farming and only haul grain now with  a 1991 Mack Ch w Bosch mechanical injection. Usually don't have to plug it in till it gets below 10-15 degrees. They are right though to recommend plugging an engine in the night begore you want to use them. Lots easier on everything. My Mack spun a bearing at 1,000,072 miles and if I had put rod and main bearings in before, that would not have happened! Oh well! That proved Rotella 15-40 oil to me! I typically DO NOT use ether as it can be very hard on components, but use WD-40 instead. Gives a lot softer start with the same effect!!!!   Works for me.     Old mechanic advice to me.
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 11 Dec 2009 at 12:01pm
Newer diesels start much easier. If you can keep your 175 out of the wind when you have it plugged in I think you'll find that having it plugged in for an hour or two at these temps will work just fine. When the -20 hits it may have to be plugged in a little longer. That's how I do it with my 7050 here in MN.
Wink
I am a Russian Bot
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 11 Dec 2009 at 3:17pm
Someone explain ether lock to me. My D17 would start easily when really cold with just a whiff through the port in the intake. Is it like "flooding" a gasoline engine? Todays ether I don't think is as potent as it used to be. It used to be that ether could be sprayed inside a tire and ignited that was being stubborn about seating the beads. We tried that about a month ago and the ether burned about like diesel dumped on the floor. All we managed to do was burn off the rubber nubbies on a new tire.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 11 Dec 2009 at 11:12pm
The EPA took the good propellant out of your ether which helped ignite it for tire inflating.Ether lock is when too much ether is ingested and it fires at enough advance to stop the upward motion of the piston.It can reverse rotation and can bend rods.An old trucker told a story many years ago about another who couldn't get his truck started on a very cold morning.Said the guy had it so loaded up with ether that when it finally fired it left the crank assy laying on the parking lot.He wasn't the kind of guy to make things up so I took him at his word.Would have been in the 60's when diesels were not common place.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eldon (WA) Quote  Post ReplyReply Direct Link To This Post Posted: 11 Dec 2009 at 11:18pm
Ether......aka  "Rodbender in a can"
