175 clutch question part 2
Joe/NC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Joe/NC Quote  Post ReplyReply Direct Link To This Post Topic: 175 clutch question part 2
    Posted: 25 Mar 2012 at 8:08pm
we have determined the shifter shaft retainer came off the clutch shifter fork shaft. The shaft must have come out the hole in the torque tube. Has anyone had this experience and is there any way to fix this w/o pulling the tractor into? It appears there is a hole at the bottom of the torque tube that on end got in, is the housing machined at the top for the shaft to fit? Hope this makes sense
Thanks,
Joe/NC
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 25 Mar 2012 at 8:13pm
It can be done with patience. You will need a pin made that will have retainer provisions outside the torque tube. It would be possible to use a original, but putting the little clip above fork pivot is almost impossible, almost but can be done. Good Luck! Tracy Martin
This page was generated in 0.069 seconds.
