175 cam in a wc |
Clay2017 ![]() Bronze Level ![]() ![]() Joined: 18 Aug 2014 Location: Ohio Points: 20 |
![]() ![]() ![]() ![]() ![]() Posted: 23 Dec 2014 at 3:01pm |
Considering doing the 175 cam in my wc. What supporting mods do I need to go with this if any? How much should I pay for the cam? Where to find one?
WF owner ![]() Orange Level ![]() Joined: 12 May 2013 Location: Bombay NY Points: 4917 |
175 (gas) cams are about as plentiful as hen's teeth. There are some guys that will custom grind a cam for you. From what I have seen on here, expect around $250.00.
Gary in da UP ![]() Orange Level ![]() ![]() Joined: 13 Sep 2009 Location: EUP of Mi. Points: 1885 |
You won't find a cam easily, get yours reground. A wd45 crank, 175 pistons, a wd45 carb, pertronix module and coil, or a magneto in tip-top shape. This will give your WC a lot of snort for not much money. You can go crazy but with a mild build like this and some good firestone 14.9x24 or 28" tires, you'll surprise those who spend more and think they need 38's to win.
mike a ![]() Bronze Level ![]() Joined: 12 Dec 2009 Location: MN Points: 168 |
dont forget to have the carb re-built. i sent mine to Motec Eng. tipton,in.for what its worth worth,i have run 28's and now 38's-build the rims -run the big rubber.
