175 and 200 three point lift arms
HudCo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Topic: 175 and 200 three point lift arms
    Posted: 27 Apr 2025 at 4:50pm
are the lift arms the same size?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 27 Apr 2025 at 4:53pm
On the splined shaft that goes thru the lift arm housing?? I think so. The lift arms are not the same on a 200/7000.
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 27 Apr 2025 at 5:44pm
sorry about that ,  i was meaning the lower three point arms with the extenable link end , or maybe called draft link assembley
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 27 Apr 2025 at 6:52pm
Draft arms. Interchangeable? Yes. Identical?? probably not. From 1961 on the first D-19 until the last 200 in 1976 there were a couple of small changes.
