175 Allis steering problem |
Mooreje1
Topic: 175 Allis steering problemPosted: 22 Sep 2022 at 9:33pm |
I have a 175 Allis with steering problems. Remotes and lift arms work fine but the only way to steer it is to just keep turning the steering wheel and use the brakes. Anyone have any ideas what’s going on?
Tracy Martin TN
Joined: 11 Sep 2009 Location: Gallatin,TN Points: 10941 |
Posted: 22 Sep 2022 at 9:38pm |
Sounds like the cylinder is leaking internally. JMHO Tracy
Mikez
Posted: 22 Sep 2022 at 10:01pm |
Yup what Tracy said. Take the steering ram and have it rebuilt.
Welcome to the forum
Mooreje1
Posted: 23 Sep 2022 at 6:22am |
Ok thanks for the help. I’ll take the steering ram and have it rebuilt.
Thanks(1)
Posted: 23 Sep 2022 at 6:40am |
Probably the problem BUT, you should disconnect each steering hose at the ram and PLUG THEM first. Then, see what you have. You should have great difficulty turning the steering wheel. If you do not, you have a pump issue.
Mooreje1
Posted: 23 Sep 2022 at 12:49pm |
Ok I’ll try that thanks
Joe(TX)
Joined: 11 Sep 2009 Location: Weatherford. TX Points: 1682 |
Posted: 24 Sep 2022 at 4:52pm |
The pump has a separate section for the power steering. There is also a relief valve between the pressure and return lines to the steering valve.
Mooreje1
Posted: 25 Sep 2022 at 2:40pm |
I plugged the steering lines at the steering cylinder and you can’t hardly turn the steering wheel so that tells me it’s the cylinder. I’ve tried to find a seal kit for the cylinder but I can’t seem to find one. Does any have a suggestion where I could get one.
Posted: 25 Sep 2022 at 4:59pm |
AGCO.
MACK
Posted: 25 Sep 2022 at 8:34pm |
Not sure Macon has a Agco dealer now but Brookfield does. Not far away. MACK
Mikez
Posted: 25 Sep 2022 at 10:06pm |
I believe it’s seal kit 72073364
Mooreje1
Posted: 26 Sep 2022 at 6:40am |
Ok thanks
Mooreje1
Posted: 01 Oct 2022 at 7:47pm |
Got the new seal kit put in the steering cylinder. It works great now. Thanks for the help everyone.
