170 tractor
bgray563 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bgray563 Quote  Post ReplyReply Direct Link To This Post Topic: 170 tractor
    Posted: 06 Jan 2019 at 4:40pm
hi guys I hope you guys can help me . I have a 170 that I need to buy aplow and disc for what size should I get don't want to work anything to hard. The ground is decent black dirt and is flat. thanks
DougS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougS Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jan 2019 at 5:39pm
3-16s
JoeO(C-MO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoeO(C-MO) Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jan 2019 at 5:41pm
10 foot wheel disk
D10 III, D15 II 3 pt, D15 II SC, 170 Gas w/shuttle, 175 Diesel UI ROPS, 185 w ROPS. AC 653 w/6 way blade, ROPS
AC 615 Ind. WD45 running/Parts.
bigal121892 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bigal121892 Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jan 2019 at 6:11pm
Dad had a 170, and pulled an Allis 3-16 slat plow, and a 13' Kewanee disk behind it. Handled the plow easy, disk was a bit much.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jan 2019 at 7:28am
The plow is pretty easy. 3 x 16's or maybe 4 x 14's. The disc is another matter. We pulled 13 ft AC discs with a tractor like that. BUT, there are 10 ft discs that take 100 HP to pull and you have 54 HP. It's all about the weight and how big of diameter the blades are.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougS Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jan 2019 at 1:28pm
And how sharp the blades are. We pulled an 8 foot tandem with a WD and it never had a problem. OTOH that disk should have been retired 10 years before then.
BrianC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BrianC Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jan 2019 at 4:10pm
I would say the plow should be 3-16. If the disk is 3pt mounted, 8ft, pull type, 8-10ft. I think you are doing it right to not take it to the limit.
How many acres are you plowing? When was the last time it was plowed.
If your 3pt is not working right (draft control or position control) then you need a pull plow or disc. Or fix the 3pt.
Do you have ballast weights that could be added if needed, are you willing to fill the tires? Also, is you backup tractor smaller or larger than the 170.
