170 gas timing |
Post Reply |
rick ky
Bronze Level Joined: 02 Oct 2009 Location: georgetown ky Points: 96 |
Posted: 03 Mar 2024 at 8:02pm |
on timing, do you use the angle hole on the adaptor or the side hole like on a d17. also what do you see when look in the opening. don't have book in front of me, but if you read in tech manual it is a little odd what is printed on how to check timing, as to set the distributor in the proper position
Orange Level Access Joined: 12 Sep 2009 Points: 20580 |
Timing hole is on the right side at the center line of the side frame. If the flywheel is rusty, you may need to take a large flat screwdriver and hold it against the flywheel with the engine running to shine it up. You are looking for "F-25" with the engine at WIDE OPEN throttle for correct timing.
Post Reply | |
