170 front pump drive hub |
Alex09(WI)
Joined: 15 Mar 2012 Location: CECIL WI Points: 1779 |
Topic: 170 front pump drive hubPosted: 08 May 2019 at 1:01pm |
Does anyone know where I can get new hubs that bolt to the front crankshaft pulley to drive the hyd pump? The bolts are not evenly spaced so the ferd drive hubs wont work. Does anyone reproduce them? Once the splines wear out what does one do?
www.awtractor.com
A&W TRACTOR 920-598-1287 KEEPING ALLIS-CHALMERS IN THE FIELDS THROUGH THE 21ST CENTURY |
AaronSEIA
Joined: 11 Sep 2009 Location: Mt Pleasant, IA Points: 2584 |
Posted: 08 May 2019 at 1:18pm |
The parts bok says it should be the same as my D17 crank pulley. I've got a post on the Knowledge base about the Ford drive coupler that fits. Unless someone else has messed up your hub, it should be the same from the D17 through the 170. AaronSEIA
Alvin M
Posted: 08 May 2019 at 1:20pm |
is it for loader pump drive is it gas or diesel
DanWi
Posted: 08 May 2019 at 2:03pm |
One of the vendors in the Old Allis News has some.
Alvin M
Posted: 08 May 2019 at 3:06pm |
countryside tractor has the parts or a kit 717-923-0421
Tracy Martin TN
Joined: 11 Sep 2009 Location: Gallatin,TN Points: 10941 |
Posted: 08 May 2019 at 8:51pm |
Alex, I make a hub and new shaft. Not exactly like original, but it won't wear out like the factory ones do. Tracy
Walter(MO)
Joined: 26 Dec 2009 Location: Warrenton, MO Points: 127 |
Posted: 09 May 2019 at 11:07am |
A local machine shop bored out the hub and pressed in a sleeve with original matching splines. Cost two years ago was less than $150.
steve fischer
Joined: 11 Jul 2011 Location: sleepy eye mn Points: 1019 |
Posted: 09 May 2019 at 1:24pm |
have new hub, shaft, sprocket and chain for both the gas and diesel 507-766-0551 Steve
Eldon (WA)
Joined: 11 Sep 2009 Location: Spokane, WA Points: 7765 |
Posted: 09 May 2019 at 1:33pm |
I welded a new splined end on mine and then it also reached the unworn splines on the shaft. female end must not have been a close enough match as it only lasted about 40 hours....Agco had the parts at that time, but wanted over $800 for the parts!
ALLIS EXPRESS!
This year: |
