160 LH tie rod end
Pafarmer92 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Pafarmer92 Quote  Post ReplyReply Direct Link To This Post Topic: 160 LH tie rod end
    Posted: 15 Jan 2023 at 2:24pm
Hello I’m looking for a left hand tie rod end for my standard ac 160 I understand they are no where to be found however I’ve heard of guys who have used one from a parts store and welded it to the old tie rod after going to a couple parts stores they are no help as to finding a tie rod end close to the size I need I was wondering if anyone on here had suggestions on one that might work thanks.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jan 2023 at 5:22pm
Might be able to help you. Let me do some digging for part numbers
Edited by Mikez - 15 Jan 2023 at 5:46pm
pump grump View Drop Down
Bronze Level Access
Bronze Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote pump grump Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jan 2023 at 8:22pm
I`ve got mine from AGCO .
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jan 2023 at 8:24pm
Most parts people today only know what that screen in front of them tell them.              MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jan 2023 at 9:06pm
if your going to do it yourself, your going to need to figure out the thread diameter and thread pitch , and left hand thread... then cross reference on a chart.. Is it METRIC or ENGLISH thread.. etc.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jan 2023 at 9:23pm
Which front axle do you have
acjwb View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote acjwb Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jan 2023 at 10:15pm
I replaced two a couple months ago.  I had to go to two different auto parts stores to finally get them.  The parts boy and I went back and just started comparing them till we found one that would work.  I took my old one with me.  The one I used was Duralast FA2101.  I got mine from Autozone but can be crossed to other brands. I also saw it online.  My tractor has power steering and the model is spelled out "one sixty"  Hope this helps.  Might pick one up at local store and make sure it fits yours.
Alvin M View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alvin M Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jan 2023 at 5:36am
I use Case IH part # K207722    cut old one off drill hole weld in or tap threads I did 12 that way
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jan 2023 at 4:57pm
72074176 is the wrong one ha. For different style front end.
This page was generated in 1.828 seconds.
