1/4" OD tubing for sediment bowl inlet |
Murph-NC
Joined: 11 Sep 2009 Location: Western NC Points: 797 |
Topic: 1/4" OD tubing for sediment bowl inletPosted: 09 May 2011 at 9:29pm |
Should I expect to be able to buy a small length of tubing to use for raising my fuel inlet off the bottom of my CA's tank? Or can you only buy that size by the roll? Or would anyone consider dropping an inch long piece in the mail to me for the right price?
'41 C w/Woods L503 mower, #3 mower, 2-way plows for C
se iowa picker
Posted: 09 May 2011 at 9:42pm |
My father in law who was a tractor tech for years told me to get some sediment bowl screen and roll it up and stick down in there. Said It would not let the junk on the bottom though and you did not have 3/4 inch of gas left in the bottom of the tank either.
CTuckerNWIL
Posted: 09 May 2011 at 10:21pm |
I had a couple hiccups in my 45one day, of course I had to be 5 miles from home at the time. I drained the tank and pulled the sediment assembly off.The inlet is the perfect size for a 1/4 " NPT tap. I cut a few threads in the top of the base and screwed a short nipple in. Reassembled it and haven't touched it since.
I do believe a place like TSC or Farm and Fleet has screens a couple inches long that have pipe threads on one end and closed on the other end. |
Tracy Martin TN
Joined: 11 Sep 2009 Location: Gallatin,TN Points: 10845 |
Posted: 09 May 2011 at 10:25pm |
Murph, Steiners sells a screen already made up for that. Cheap enuff too. HTH Tracy Martin
Edited by Tracy Martin TN - 09 May 2011 at 10:26pm |
Murph-NC
Posted: 10 May 2011 at 7:45am |
Thanks guys... I'm glad there are other options.
Edited by Murph-NC - 10 May 2011 at 7:46am |
David(Stockbridge)MI
Joined: 15 Sep 2009 Location: Stockbridge MI Points: 536 |
Posted: 10 May 2011 at 7:51am |
we have what you are looking for on our web site, a push in screen for sediment bowl.
All "NEW" Web Site http://www.djstractorparts.com
2035,A,U,UC,WF unstyled,WF styled,WC High Crop (cane),RC,B,IB,C,CA,WD,WD45,G,D10,D12,D14,D15,D15 II,D17,D19,WC styled,WC unstyled H3 crawler |
Kip-Utah
Joined: 14 Sep 2009 Location: Southern Utah Points: 918 |
Posted: 10 May 2011 at 8:57am |
I've also done the 1/4" pipe nipple deal, only I used brass ones with several small holes drilled in the sides.
Gary in da UP
Joined: 13 Sep 2009 Location: EUP of Mi. Points: 1885 |
Posted: 10 May 2011 at 9:49am |
A small tightly wound spring works as a strainer too.
Butch(OH)
Posted: 10 May 2011 at 12:24pm |
Before ya'll rush out and get your 1/4" pipe tap and fittings I'm pretty sure the guys mean 1/8"
Murph-NC
Posted: 10 May 2011 at 1:26pm |
Yeah, I was actually thinking they might mean 1/16 NPT... the inlet hole in mine is 1/4", and the tap drill size for 1/16 NPT is 0.246. Although that size might not have a large enough ID. I'll make one or the other work if I go that route. Thanks
CTuckerNWIL
Posted: 10 May 2011 at 3:02pm |
Glad somebodies awake. I know I didn't drill out the hole on mine, just ran a tap in it. |
GBACBFan
Joined: 11 Sep 2009 Location: Green Bay WI Points: 2662 |
Posted: 10 May 2011 at 5:24pm |
What are they listed under, David, I couldn't find them.
are genuine." - Mark Twain |
Posted: 11 May 2011 at 7:29am |
Here is the item.
CTuckerNWIL
Posted: 11 May 2011 at 12:10pm |
It's on this page. http://djstractorparts.intuitwebsites.com/ENGINE-COMPONENTS.html
Posted: 11 May 2011 at 2:23pm |
Thanks Tucker, Took picture AM and had wife load. Adding new parts and pieces as I find them or have made. NOTE if anyone is looking for a part and it's not on the web site, give me a call as we might have it and just have not had time or forgot to load it. THANKS David 734-320-3470 www.djstractorparts.intuitwebsites.com
