WD45 Starter
Mark (ECIN) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mark (ECIN) Quote  Post ReplyReply Direct Link To This Post Topic: WD45 Starter
    Posted: 05 Oct 2026 at 4:21pm
How is the starter held on.  Mine is loose,  you can wiggle it around where it goes into the block.
When you start the tractor it moves.
dr p View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dr p Quote  Post ReplyReply Direct Link To This Post Posted: 05 Oct 2026 at 6:43pm
Should be frictional fit in the housing with a set screw on the side
Alberta Phil View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alberta Phil Quote  Post ReplyReply Direct Link To This Post Posted: 05 Oct 2026 at 6:46pm
There is a set bolt with a lock nut on the left hand side of the bell housing where the starter mounts. Loosen the lock nut and tighten the set bolt.  It has a tapered end and fits into a corresponding tapered hole in the nose of the starter.  Make sure that the bolt taper is in the hole and tight, as that is your main source of grounding for the starter.
Edited by Alberta Phil - 05 Oct 2026 at 6:46pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mark (ECIN) Quote  Post ReplyReply Direct Link To This Post Posted: 06 Oct 2026 at 8:01am
Thanks guys.
This page was generated in 0.088 seconds.
