ignition |
Page 12> |
mufflerboltz
Joined: 03 Oct 2012 Location: New Glarus, Wi Points: 371 |
Topic: ignitionPosted: 25 Oct 2012 at 5:45pm |
is there a good aftermarket ignition system that can be ran on a 226 engine? like a MSD set up, i would like to try it and if anyone has done this can you help me out on what i should all run?
Thanks
Charlie175
Joined: 11 Sep 2009 Location: Shenandoah, VA Points: 6381 |
Posted: 25 Oct 2012 at 6:57pm |
Check the class rules, some places do not allow electronic setups
Charlie
'48 B, '51 CA, '56 WD45 '61 D17, '63 D12, '65 D10 , '68 One-Ninety XTD |
DrAllis
Posted: 25 Oct 2012 at 7:04pm |
If you have new spark plugs that are gapped properly and fresh points ( or electronic pointless set-up) you'll see no HP improvement in an AC Power Crater engine with any other ignition system at under 3,000 rpm. It's hard to beat a spark plug located in the center of the combustion chamber.
mlpankey
Joined: 13 Sep 2009 Location: Vols country Points: 4580 |
Posted: 26 Oct 2012 at 5:08pm |
With the capacitive discharge ignitions like msd .I have started engines just by turning on the ignition and never turning the engine over with the starter. ofcoarse it was oxygenated fuel and the cylinder was aligned to fire on compression . Sometimes all the stars align like that. So i tend to think they have some hotter better fire. jmho |
Mrgoodwrench
Joined: 03 Apr 2011 Location: CHICORA PA Points: 2098 |
Posted: 26 Oct 2012 at 5:24pm |
the advantage in a msd ign in the "Multi Spark Discharge" meaning it fires a little before through a little after the typical one shot fireing point. that mostly comes into plat at higher rpm but the do fire hot with a hot coil and create a more complete burn through all rpm ranges. but i doubt that youd notice much difference over a properly working factory system with a good coil unless you are dealing with high compression
There are 3 ways to do job GOOD, FAST, CHEAP. YOU MAY CHOOSE 2. If its FAST & CHEAP it won't be GOOD, if it's GOOD & CHEAP it won't be FAST, and if its GOOD & FAST it won't be CHEAP!!!!
wi50
Joined: 24 Sep 2010 Location: weegieland Points: 1010 |
Posted: 26 Oct 2012 at 5:57pm |
If you really want to spend time and money on your engine put a ground cam in it and degree it in correctly. If you just want to spend time with your engine degree your stock cam in correctly to about 104* ATDC intake centerline.
You'll notice the advantage from the above. You won't notice any advantage weather you have a good set of points or an electronic with an MSD. Nothing beats a good mag though. |
mufflerboltz
Posted: 26 Oct 2012 at 6:02pm |
all good point of views, those are the answers i was looking for! I have noticed hot spark with a hotter coil but with the hotter coil i have burned up point sets!
Mrgoodwrench
Posted: 26 Oct 2012 at 6:39pm |
leave the coil loose the points....pertronics it the only way to go with a hot coil
mlpankey
Posted: 27 Oct 2012 at 8:33pm |
Edited by mlpankey - 27 Oct 2012 at 8:39pm |
Rod B
Posted: 29 Oct 2012 at 10:20am |
I know of some running nothing more than a petronix electronic ignition and a good coil running RPM's over 5000 with no problems. Take WI's advice and change the cam timeing or get a ground cam. The most important thing for engine performance is the closing point of the intake valve. By altering the cam timeing of your stock cam you are changeing the point of closure to allow maximum cylinder filling. Low RPM engines need to be closed sooner than higher RPM engines. As the intake valve starts to close the pressure begins to rise in the intake port, the mass of air and fuel rushing into the cylinder slows down and pressure rises. When the piston comes around BDC or bottom dead center and starts to rise on compression, pressure begins to build in the cylinder. Pressure in the intake must rise high enough to overcome the cylinder pressure in order to continue to fill the cylinder. When you change your cam timeing the position of the piston to intake valve cycle change helping to ram more air/fuel into the cylinder.
Cranking compression pressure has little to do with how the engine will respond to these modifications when running. It will indicate changes but the highest compression will come after the cam is to far retarded. Read some old threads on cam timeing and have a good laugh at the armchair expert.
mlpankey
Posted: 29 Oct 2012 at 8:35pm |
Rod your wrong as usual advancing the cam raises cylinder pressure not retarding it as you stated. When you advance the cam you close the intake valve sooner. You cant build compression untill valves are closed. Your so good for a laugh. When your in your chair look up effective stroke and how closing the intake valve sooner makez for a longer effective stroke.
Edited by mlpankey - 29 Oct 2012 at 8:40pm |
Rod B
Posted: 29 Oct 2012 at 9:00pm |
You're ignorance is forgiven, when you get some experience you will understand what I posted. As in Larry's sig line "I can explain it to you but I can't understand it for you". So true here.
We all know that advanceing the cam raises cylinder pressure. But peak pressure will come when the cam is to far retarded. Try it sometime and see where peak pressure is and how it runs at that point. Sounds like a good homework assignment for pank. He still hasn't done the last ones I gave him. I'm sorry, I forgot. Pank has no clue how to degree a cam, or where to set it at or how it works. Past threads have shown that. I wouldn't take any camshaft advece from pank, he still thinks that no matter where you place an 8 degree chevy bushing the cam timeing will change 8 degrees no matter what. No consideration to basic geometry. Pank realized his invalid attempts at understanding camshafts upon unable to move the pulling sled so he bought one from someone who had it figured out. Edited by Rod B - 30 Oct 2012 at 7:16am |
wi50
Posted: 29 Oct 2012 at 9:21pm |
......sooner is the same thing as advanced.... just sayin. Sooner, earlier and advanced share a common meaning in the english language. But on the ignition subject at hand, I built a GM HEI setup probably 15 years ago for my pulling tractor. It's fine but a friend of mine from across the river in MN turns his engine pretty hard and I'm sure it's got a Petronix a good coil and nothing more. A few friends run 6 cyl's with the same setup that run pretty fast. You've got to rember that with a 4 cyl there's a lot of room between terminals on the cap and a lot of dwell time for the coil. I have seen a difference in caps, rotors and points from cheap alumnium terminals to good brass terminals. We had a tractor on the dyno and for kicks changed things around and seen some gain when switched to Napa Echlin which had brass terminals but the last one I got there had junk alumnium. I'll have to try and find a few good ones and put away for future tuneups. Edited by wi50 - 29 Oct 2012 at 9:28pm |
mlpankey
Posted: 30 Oct 2012 at 7:22am |
rod wrote the highest compresion reading will come after cams to far retarded . and that is wrong read again . the highest compression reading will come when cam is advanced to correct degree If you add another degree or two compression will start to fall off but the cam is still being moved in the advanced direction . Retarding a cam always reduces cylinder pressure . ford did it alot on detonation prone engines. here is rods statement cut and pasted so you can see his error."It will indicate changes but the highest compression will come after the cam is to far retarded" . engines that run under 6000 rpms and need to lug see benefits from advancing and checking for the highest cylinder pressure reading at starter cranking speeds . it really increases the torque and power due to the effects on "effective stroke".
Edited by mlpankey - 30 Oct 2012 at 7:33am |
Rod B
Posted: 30 Oct 2012 at 7:39am |
Why don't you take some time and play with the allis and tell us at what point peak pressure happens. You'll find that the cam will be to far retarded at 107 degrees. Trust me, you'll want it more advanced. It's because of the inline 4 cyl design with siamesed intake port. 3 valves in the paired cylinders have activity to close to each other. This isn't about a ford or 6000 rpm. When the engine is running up to speed things happen that don't show at cranking speed.
Edited by Rod B - 30 Oct 2012 at 7:47am |
mlpankey
Posted: 30 Oct 2012 at 8:09am |
Edited by mlpankey - 30 Oct 2012 at 8:20am |
mlpankey
Posted: 30 Oct 2012 at 8:26am |
as for the siameezed or paired valves this is where ron iskyderians splatter pattern cam makes its biggest impact in performance.
Rod B
Posted: 30 Oct 2012 at 8:29am |
Go read my original post in which I say "by altering the timeing of your stock cam".
Sure a custom ground has different charistics. That's not up for debate. You can stop your teenage girl cat and mouse games by simply learning to read. |
mlpankey
Posted: 30 Oct 2012 at 8:37am |
I do read and simply posted your inaccuracy . quote rod ,"It will indicate changes but the highest compression will come after the cam is to far retarded" admitt this statement is wrong and my engine intellegence caught your mistake and move on.
Rod B
Posted: 30 Oct 2012 at 8:58am |
I posted where peak pressure is and 107 is retarded further than 104. You have no intellegance if you can't figure that out. |
mlpankey
Posted: 30 Oct 2012 at 10:19am |
smaller the number the more advanced . 107 is not retarded its advanced to 107. peak pressure may be at 107 ,104 ,102. or 92 degrees depending on the size of motor and the duration of the cam you simply just dont pull a number from the magicians hat you research by doing it on each and every build. the cam is not retarded untill the degree number increases larger than it is at straight up.
Edited by mlpankey - 30 Oct 2012 at 10:20am |
Rod B
Posted: 30 Oct 2012 at 11:29am |
We are not dealing with custom cam. Peak pressure is at 107 which is retarded compared to 104. So you can play around all you want but this still means the same thing as in my original post.
Are your failed attempts at building a competitive pulling engine a result of your fake engine intelligence or yout real engine ignorance? |
mufflerboltz
Posted: 30 Oct 2012 at 12:43pm |
Wow gentlemen, all i asked for is ignition advise! Not a battle about cams and compression! (like i have seen in alot of other post) Im not trying to build a high dollar puller, just a good 60-70 horse machine!
Gary in da UP
Joined: 13 Sep 2009 Location: EUP of Mi. Points: 1885 |
Posted: 30 Oct 2012 at 12:44pm |
Getting back on track with your ignition question. I have been very satisfied with pertronix systems and also use their stealthy stock looking black coil. There are two more things to do that are cheap upgrades for your ignition. First is to index your plugs to each cylinder. , when that is done trim the outer electrode on your plugs to a sharp square that just ends at the outer edge of the center electrode, This opens up the spark to face the piston top, and you can open the gap then to as much as 45 thou. This is a worthwhile mod...... for not a lot of money.
Mrgoodwrench
Posted: 30 Oct 2012 at 4:49pm |
not taking sides but 107 degrees btdc is more advanced than 104 degrees btdc
mlpankey
Posted: 30 Oct 2012 at 7:52pm |
On the ignition when you find the brown residue inside the black distributor cap then you will need to drill holes between the post to let the plasma ions out. If your worried about moisture then you will need to go to the hei cap with wider posts.
Rod B
Posted: 31 Oct 2012 at 6:41am |
That is correct, but when dealing with intake centerline timeing is measured ATDC, in which lesser numbers are advanced. You boys don't need to go drilling every distributer cap you have full of holes. They worked fine for the last 60 years with little regular maintenance and will work for many more. Index the plugs so the ground strap isn't hindering spark exposure in the plug pocket of the head, gap your plugs and if available I chose NGK. Had the best luck with them, not that it makes any difference. The biggest performance upgrade some people can do is to leave things alone and not take advice from bad sources. Edited by Rod B - 31 Oct 2012 at 6:45am |
BennyLumpkin
Joined: 22 Mar 2010 Location: Centre Hall, PA Points: 2657 |
Posted: 31 Oct 2012 at 8:24am |
I love how a simple question becomes a pissing contest lol
Central PA Allis Express
1934 WC254 1945 WF 1945 WC135755 1951 WD68085 1953 WD45-150217 1957 WD45D-230744D B110 |
WildBill
Joined: 26 Aug 2012 Location: Mandan,ND Points: 190 |
Posted: 31 Oct 2012 at 1:15pm |
Reminds me of our presidential election!! SUCKS . Poor mufflerboltz just trying to take his pulling career to the next level turns into a suicide attempt?? I love my Allis tractors but cannot stand fighting .
Allis fan for life ! B,C,2-WC'S,WD45G,D19G,190xt ,LLSS 8010, terra tiger refurbished
mlpankey
Posted: 31 Oct 2012 at 3:59pm |
every distributor cap wouldnt have the brown residue from plasma in it just the ones sending several joules to the plug and you dont need that unless your running high compression ratios.
Edited by mlpankey - 31 Oct 2012 at 4:00pm |
Page 12> |
