Tire guage |
whatscooking
Topic: Tire guagePosted: 10 Aug 2026 at 8:47am |
Haven't delt with checking air in a tire lately that has calcium but rember it as destructive to any guage. How do you do it?
rtwfarm
Joined: 26 Feb 2012 Location: nebraska Points: 1390 |
Posted: 10 Aug 2026 at 9:14am |
Valve stem straight up top. Put a little air in tire then check
8070nc
Joined: 21 Mar 2019 Location: North Carolina Points: 932 |
Posted: 10 Aug 2026 at 9:15am |
I dont run any calcium. Ive git methanol in mine. I made a checker for tires with fluid that uses regular pressure guages. Doesnt hurt them even if they get fliud in them
1984 80780
1957 D14 DES 300 with 25000 engine 616 tractor |
ACinSC
Joined: 16 Dec 2015 Location: South Carolina Points: 3388 |
Posted: 10 Aug 2026 at 11:25am |
Thanks for the tip Ryan! All of my D 15 tires have water in them. Next time I'll try adding a little air before checking
Jim.ME
Posted: 10 Aug 2026 at 11:43am |
Stem at the top and use a gauge rated for liquid in tires. Here are three and there are others rated for air/water filled Ag tires.
Milton S-928W Slime 2007-A Tru-Flate 17-517
Allis dave
Joined: 10 May 2012 Location: Northern IN Points: 3182 |
Posted: 10 Aug 2026 at 12:22pm |
You cna buy a gauge rated for fluid. They usually have a little ball on the tip of the stem. I have one but still turn the stem to the top.
DanWi
Posted: 10 Aug 2026 at 1:11pm |
If you can wash the gauge off after use and spray it with wd40 0r something better or at least spray it with wd40 even if you can't wash it. If tires are full I have even parked on a hill to tip fluid away from the stem.
SteveM C/IL
Joined: 12 Sep 2009 Location: Shelbyville IL Points: 9238 |
Posted: 10 Aug 2026 at 1:18pm |
I put stem up top,jack wheel off ground and give a couple shots of air with plain old air chuck. After that I use the Milton inflator gauge. I change valve cores every 2 yrs part of the reason for jacking up. They get ate up and you find yourself digging out corroded pieces if left too long.
ACinSC
Posted: 10 Aug 2026 at 1:50pm |
Thanks Jim. I ordered myself the Milton gauge.
ACinSC
Posted: 14 Aug 2026 at 8:04am |
Received my Milton S 928 tire gauge today. Haven't used it yet but seems well made. Even claims Made in USA !
