8010 elec lift pump Holley or Carter?
PeteMN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote PeteMN Quote  Post ReplyReply Direct Link To This Post Topic: 8010 elec lift pump Holley or Carter?
    Posted: 21 Jun 2026 at 10:16pm
Some guys tell me to use the Red Top Holley, but I looked on the Holley website and didn't see any that were rated for diesel (not the red or blue or black ones).  The Agco pictures look like a Carter pump which is what I have now.  I think we figured out today that the fuel is draining back to the tank when the tractor sits for an extended period of time with a low fuel level in the tank.  Anybody have that happen to their tractor?
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jun 2026 at 10:32pm
If it can handle gasoline why wouldn't it be ok with diesel? Doesn't the return have a pipe hanging in tank which has been known to fall off?
Alvin M View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alvin M Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jun 2026 at 5:05am
You Can use NAPA FE 0539 or DELPHI  FE0539 Carter P4594 I used 5 from NAPA they near me
im4racin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote im4racin Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jun 2026 at 5:48am
The new Napa number is b0219e
8070nc View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8070nc Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jun 2026 at 9:56pm
Ive got a 8070 that was doing that. Turned out to be the return line to the tank. Original was plastic. I put a rubber line on it and it fixed it
1984 80780
1957 D14
DES 300 with 25000 engine
616 tractor
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8070nc Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jun 2026 at 10:00pm
I wish i could remember how i figured that out. I think i just ran out of things to try
1984 80780
1957 D14
616 tractor
