Hd6g clutch problems
Jhilton69 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jhilton69 Quote  Post ReplyReply Direct Link To This Post Topic: Hd6g clutch problems
    Posted: 16 Jul 2025 at 10:04pm
Hey yall just got back up from flordia. Put my brother in law on my ol gal and now the clutch won't engage. I figured he knew what he was doing since he runs a crew of asfault guys. I rode with him at first and he got it I thought. After an hour or so he messed her up. When I pulled the floorboard panels up I noticed a rod on the right side that moves with the clutch handle bit it's not connected to anything and I can't find any information on it. Figured I'd see whatbuall think before opening her up and adjusting the clutch on her. Please help.
gemdozer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote gemdozer Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jul 2025 at 7:02am
The right side rod is the plunger shifting lock
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jhilton69 Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jul 2025 at 10:55am
Thank u what does it go too? I haven't found anywhere it hooks up too. Does it affect the clutch engagement?
Post Options Post Options   Thanks (0) Thanks(0)   Quote gemdozer Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jul 2025 at 12:53pm
THE rod should be connect to a other rod with a boot on and she is going in the front transmission  shifting housing and this rod is loock the transmission in gear when the cluch is angaged and this should affect the cluch.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jhilton69 Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jul 2025 at 8:58pm
I searched around and couldn't find any other rod for it to hook too. I didn't get a chance today to do a pull test on the cluth lever gonna do that tomorrow.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jhilton69 Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jul 2025 at 1:08pm
Well done my pull test took a lil over 35 pounds to pull the lever over. Any ideas?
Post Options Post Options   Thanks (0) Thanks(0)   Quote gemdozer Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jul 2025 at 2:22pm
The master need 25lbs to 30 lbs maximum and the cluch should angage with a distinct over-center snap (engine stop)
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jhilton69 Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jul 2025 at 7:56pm
Ya i can feel it snap over like it's supposed too. I got tje floorboards out and when pulling the lever back everything with the exception of that rod on the right side looks good
Ray54 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ray54 Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jul 2025 at 11:40am
I am lost as to what is not working.
There is rod that locks the shifter up when the clutch is engaged. Unless that is released it should not come out of gear.  Is that the trouble?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jhilton69 Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jul 2025 at 12:37pm
I can start her in gear to move her around to stop i just shut her down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jhilton69 Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jul 2025 at 10:36pm
It acts like it's not engaging the clutch when the lever is pulled back. But when I checked the pull it was just over 35 pounds. The floorboards are out and watching the levers it looks like it's working. Bit it won't go in gear when running just grinds
Codger View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Codger Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jul 2025 at 5:54am
When you pull that handle back you are engaging the main clutch and if transmission is in neutral, it is going to grind if you attempt to put the transmission into a gear. If that rod mentioned were operating correctly, you would not be able to move that shifter with the clutch engaged.
With the handle pushed forward, the clutch is released. You can now shift gears in the transmission. With the transmission in a selected gear position, and the handle pulled back engaging the clutch, the tractor should move and you should not be able to move the transmission shift lever.
If I am reading your postings correctly, the rod mentioned is not connected to the shift mechanism and laying loose. When you push the clutch lever forward, the main clutch is not releasing and continues to spin the transmission? This is either a warped clutch disc, pressure plate, (clutch cover) or sections of the friction material have broken free from their mountings and are binding between the flywheel, and pressure plate of the engine causing a frictional "drag". If clutch adjustment does not solve the issue, clutch apparatus replacement is your next option along with bushings, and any linkage points involved.
From this vantage point I would say it is probably time to replace the clutch assembly.
That's All Folks!
Post Options Post Options   Thanks (0) Thanks(0)   Quote gemdozer Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jul 2025 at 6:15am
When you desangage the master cluch the brake cluch have to stop the cluch turning for angage the transmission
Post Options Post Options   Thanks (0) Thanks(0)   Quote Codger Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jul 2025 at 6:38am
Those have a clutch brake incorporated? Have never worked on one myself.
That's All Folks!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ray54 Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jul 2025 at 2:49pm
General Gear out of Boise Id has parts books and service manuals on line for most older crawlers.  They have HD 6 books as just looked at them. They have been the go to for steering clutch parts for a long time. Looks as if they may have the wear parts for the master clutch as well.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jhilton69 Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jul 2025 at 3:26pm
I've owned and driven the machine for the last 2 years with no problem like arising. I did read that letting her set with the clutch disengaged for a long period of time will cause the disk to stick to the flywheel. I did start her in low gear and drove to a tree put her in full throttle against the tree. All she did was dig a big hole from the tracks.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jhilton69 Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jul 2025 at 3:28pm
Now that u mentioned that I don't think I see the driveshaft stopping while clutch disengaged gonna check that after I get my backhoe finished up today
Post Options Post Options   Thanks (0) Thanks(0)   Quote gemdozer Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jul 2025 at 8:33pm
Like I said the brake cluch is not working
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jhilton69 Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jul 2025 at 8:51pm
Ya im gonna check that tomorrow almost got the backhoe done. Pulling that shifter out has been a pain in the backside. I finally got it out tried burning the old wire loom out but that failed lol even with has poured in it. Lol
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jhilton69 Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jul 2025 at 10:05pm
Well im stuck now. Worked a li l on my ol gal this morning and didn't end well. I tried adjusting the main clutch by a few turns and now I aint got enough strength to pull the lever back. I was trying going to get it down to 30lbs but somehow ending up making it worse. I know to add more pressure turn it clockwise so I turned it counterclockwise. Any ideas would be helpful please.
Adrian View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Adrian Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jul 2025 at 10:22pm
I have just looked it up and counterclockwise tightens it. Also if you need to buy parts it should be an Alburn clutch. Good luck I hope you get it sorted.
Les Kerf View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Les Kerf Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jul 2025 at 7:29am
Originally posted by Jhilton69 Jhilton69 wrote:
... I tried adjusting the main clutch by a few turns and now I aint got enough strength to pull the lever back....
Ummm... please define 'a few turns'. This type of clutch typically needs only a few 'notches' of movement on the adjuster gizmo.
Post Options Post Options   Thanks (0) Thanks(0)   Quote gemdozer Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jul 2025 at 11:11am
The HD5-HD6 use a AUBURN and some use ROCKFORD cluch and when these are to much adjusted you need to desajusted and try to readjusted 2 or teeth and try to angaged the cluch lever until you have a good snap and am still have some parts for.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jhilton69 Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jul 2025 at 3:08pm
According the the operating and field maintenance it says to go clockwise to tighten. It's an original book not a remake. Just looked again and it clearly says to turn clockwise. I would think it's the same as all equipment the direction would be from the drivers seat.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jhilton69 Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jul 2025 at 3:10pm
I know where i screwed up when I was working on her it was late in the night after a long day. After adjusting her i forgot to lock the plata in place and I started the engine and tried the clutch. I believe that's what tightened her down so tight.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jhilton69 Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jul 2025 at 3:11pm
what kind of parts do you got
Post Options Post Options   Thanks (0) Thanks(0)   Quote Les Kerf Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jul 2025 at 4:01pm
Whee! That will do it fer sure Tongue
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jhilton69 Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jul 2025 at 5:35pm
That's makes me not feel like a fool at least. Anyone knowbof a place to get the clutch break pads at?
Post Options Post Options   Thanks (0) Thanks(0)   Quote gemdozer Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jul 2025 at 7:53pm
All the breake shop can make these breake pads and am still have some parts for transmission ,final drive,motor,master cluch,stering cluch,hydrolic
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jhilton69 Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jul 2025 at 8:34am
where you out of? Im here in Lyerly Georgia
