Pressure Testing Old Tractor Cooling Systems |
wjohn
Topic: Pressure Testing Old Tractor Cooling SystemsPosted: 10 hours 27 minutes ago at 9:30am |
What's everyone's favorite way/tool to pressure test radiators and such on our old AC tractors? I almost picked up a radiator pressure testing kit from Harbor Freight the other day but it didn't look like any of the cap adaptors would work.
ACinSC
Joined: 16 Dec 2015 Location: South Carolina Points: 3348 |
Posted: 10 hours 23 minutes ago at 9:34am |
I used one from AutoZone on my D 15. Had to put up a deposit but got it back when I returned the tester. Good luck
55allis
Joined: 30 Jun 2020 Location: Griswold Iowa Points: 1419 |
Posted: 10 hours 22 minutes ago at 9:35am |
An air compressor and a leather or rubber glove. Just be careful not to over pressure it.
plummerscarin
Posted: 9 hours 24 minutes ago at 10:33am |
I "borrowed" a test kit from O'Reilly. Paid the deposit, (full retail price) and never returned it. Of all the test caps in the kit, the only one I've been able to use is the rubber expansion cap. I've used it so many times over the years I don't miss the "deposit".
Coke-in-MN
Joined: 12 Sep 2009 Location: Afton MN Points: 42472 |
Posted: 5 hours 29 minutes ago at 2:28pm |
In the past I have made up a hose fitting with a T in it , then using a regulator to control air pressure just charge system ( on trucks and cars ) using present cap on radiator .
On tractor one would need to tap into block drain with a T and gauge and valve . |
DMiller
Joined: 14 Sep 2009 Location: Hermann, Mo Points: 36541 |
Posted: 4 hours 32 minutes ago at 3:25pm |
Have my own, bought close to Forty years ago, have to take apart and lube the piston ring occasionally but make pressure just fine and gauge is as accurate as I need. Used on Allis 7G as well the 180 and numerous OLD Cap Style cars or trucks. Not bought a update cap style for the screw on caps.
Edited by DMiller - 4 hours 32 minutes ago at 3:25pm |
