D12 rebuild
 Post Reply Post Reply Page  <1 345
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 12 May 2023 at 12:55pm
hunter321 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote hunter321 Quote  Post ReplyReply Direct Link To This Post Posted: 12 May 2023 at 1:46pm
stupid thing to ask but i would have to remove the bucket and loader and cement front weight before attempting to pull the engine.
if i took the backhoe part of if i could i dont think i could ever get it back on
Edited by hunter321 - 12 May 2023 at 2:02pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 12 May 2023 at 3:37pm
normally you roll the motor forward with the tires... I did a Backhoe tractor a few years ago... Transmission , rear end, tires, backhoe dont move. Block that solid..... I set  bucket on the ground and blocked under the loader frame so it was stationary.. removed the radiator and everything around it... pulled the motor forward 3 inches and lifted out of the loader frame... but you would need a lift of some sort ..... have also seen pull the motor forward and drop to the ground and drag out from under the loader frame.. if you have room.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 12 May 2023 at 3:45pm
This is a CASE 530 under an 8 ft awning... I disconnect the front axle / tires/ etc and rolled forward a foot toward the bucket.. Pulled the motor and dropped it out the bottom.. just plenty or cribbing under the loader frame and  transmission area.
