D12 rebuild |
Page <1 345 |
Joined: 11 Sep 2009 Location: illinois Points: 93381 |
Posted: 12 May 2023 at 12:55pm |
hunter321
Posted: 12 May 2023 at 1:46pm |
stupid thing to ask but i would have to remove the bucket and loader and cement front weight before attempting to pull the engine.
if i took the backhoe part of if i could i dont think i could ever get it back on Edited by hunter321 - 12 May 2023 at 2:02pm |
Posted: 12 May 2023 at 3:37pm |
normally you roll the motor forward with the tires... I did a Backhoe tractor a few years ago... Transmission , rear end, tires, backhoe dont move. Block that solid..... I set bucket on the ground and blocked under the loader frame so it was stationary.. removed the radiator and everything around it... pulled the motor forward 3 inches and lifted out of the loader frame... but you would need a lift of some sort ..... have also seen pull the motor forward and drop to the ground and drag out from under the loader frame.. if you have room.
Posted: 12 May 2023 at 3:45pm |
This is a CASE 530 under an 8 ft awning... I disconnect the front axle / tires/ etc and rolled forward a foot toward the bucket.. Pulled the motor and dropped it out the bottom.. just plenty or cribbing under the loader frame and transmission area.
Page <1 345 |
