Allis Chalmers WD45 Diesel project |
Page 123 8> |
55allis
Joined: 30 Jun 2020 Location: Griswold Iowa Points: 1437 |
Topic: Allis Chalmers WD45 Diesel projectPosted: 01 Jul 2020 at 10:16am |
Hi to all, just got me a nice WD45 with a D19 diesel repower engine in it. It has been setting for about 20 years in a machinery shed. Put new diesel in it and it started right up.
Got it to a shop so I can work on it and so far I took it in to get rid of the fluid in the rear tires and change the oil. Would post a picture but it won’t load. |
IBWD MIke
Joined: 08 Apr 2012 Location: Newton Ia. Points: 4454 |
Posted: 01 Jul 2020 at 12:35pm |
Good luck with the tractor and welcome to the forum.
55allis
Thanks(1)
Posted: 01 Jul 2020 at 5:57pm |
Got to looking at it and the radiator and the diesel pump are leaking.
DSeries4
Joined: 12 Sep 2009 Location: Ontario, Canada Points: 7723 |
Posted: 01 Jul 2020 at 9:02pm |
Welcome to the world of buying old tractors. Not trying to bring you down but you WILL find more things wrong with it the more you look. Deal with them when you stumble across them.
55allis
Posted: 01 Jul 2020 at 9:12pm |
Yes I know that from experience!!
Does anyone know how hard it is to take apart and put together those pumps are? |
DSeries4
Posted: 01 Jul 2020 at 9:45pm |
These pumps are NOT for an amateur! Send it to a shop that knows these pumps.
55allis
Posted: 03 Jul 2020 at 1:01pm |
My cousin might be able to help on the pump so I might be in good luck. I got the tractor from him.
Sugarmaker
Joined: 12 Jul 2013 Location: Albion PA Points: 8689 |
Posted: 03 Jul 2020 at 3:04pm |
55allis,
Welcome! Glad the tractor is running. As mentioned they tend to mark there territory. Every thing about a diesel is a little more complicated than a gas job. But you have a rare tractor. Under 7000 made I believe. You might need to reduce the picture size to around 800 x 600 pixels for it to load better. Regards, Chris |
55allis
Posted: 04 Jul 2020 at 10:57pm |
Ok thanks
DougG
Posted: 05 Jul 2020 at 10:37am |
Good looking tractor
55allis
Posted: 08 Jul 2020 at 6:37pm |
How thick is a late d17 diesel head gasket?
MACK
Posted: 08 Jul 2020 at 9:09pm |
.065. MACK
55allis
Posted: 08 Jul 2020 at 10:06pm |
Ok thanks Mack.
it has d17 pistons and the valves hit the pistons so I think a thicker head gasket will fix that problem. Thanks!! |
JC-WI
Joined: 11 Sep 2009 Location: wisconsin Points: 34726 |
Posted: 09 Jul 2020 at 8:15am |
Have you physically checked to see by rotating engine and then checking the valve for movement at tdc of engine with the valve open?
55allis
Posted: 09 Jul 2020 at 11:30am |
When my cousin overhauled it 30 some years ago he put d17 pistons in it and so he drove it 10 miles right after he overhauled it and it bent a few pushrods, so he was in a hurry to use it and retarded the camshaft and fixed all the pushrods it bent
Now if that explains what happened |
MACK
Posted: 09 Jul 2020 at 8:53pm |
Don't think there is a thicker head gasket + that would increase the chances of blowing head gasket. MACK
MACK
Posted: 09 Jul 2020 at 8:55pm |
Machine some from top of pistons. MACK
55allis
Posted: 09 Jul 2020 at 9:23pm |
I think it will be fine with a d17 head gasket besides they are a bit thicker.
MACK
Posted: 10 Jul 2020 at 6:49am |
All 230-262 diesel head gaskets are the same thickness. MACK
Lonn
Joined: 16 Sep 2009 Location: Назарово,Russia Points: 29821 |
Posted: 10 Jul 2020 at 7:06am |
There must be a difference in cams for the D17 pistons to hit in a D19 diesel. The later D19 compression ratio is 15:1 and the D17 is 15.7:1. Machining pistons would fix it. Of course I have little experience in those engines........ Looking at the parts page it looks like the cam changed and when using the new cam you had to change to newer pistons. I'm just babbling for my own edjamacation.
Wink I am a Russian Bot |
SteveM C/IL
Joined: 12 Sep 2009 Location: Shelbyville IL Points: 9240 |
Posted: 10 Jul 2020 at 8:46am |
Do the diesels have flat surface where valve sets requiring specific stand out? Someone put seats in my 8070 before I got it and didn't set them down...had valve marks in carbon on 4 pistons.
Lonn
Posted: 10 Jul 2020 at 11:43am |
I believe they are flat
Sugarmaker
Posted: 10 Jul 2020 at 6:17pm |
55 allis,
I can see you have some experience in these engines and that's good. I do not. A good friend and good mechanic on these 45D engines gave me advice on them. If you want to chat P.M. me. Thanks for posting the picture of your tractor! Regards, Chris
Albert
Posted: 10 Jul 2020 at 8:27pm |
The AGCO head gaskets had a sheet of paper inside them on the piston machining needed. AGCO has killed the head gasket but Tony at Tony's tractor has one left of the AGCO gaskets left'
Albert |
55allis
Posted: 10 Jul 2020 at 9:21pm |
Ok but already got one coming
Thanks |
55allis
Posted: 14 Jul 2020 at 7:42am |
Got the one rim and tire put together and painted [IMG]http://
55allis
Posted: 14 Jul 2020 at 7:44am |
![]() Here is the picture, it didn’t work the first time |
55allis
Posted: 14 Jul 2020 at 8:24am |
![]() Here is a better picture |
IBWD MIke
Posted: 14 Jul 2020 at 2:26pm |
55, that looks great!
Sugarmaker
Posted: 14 Jul 2020 at 9:05pm |
Nice big 16.9's on the 45D! I like it. Wheel looks good!
Thanks for posting. Regards, Chris
Page 123 8> |
