7080 Hyd couplers |
LB0442
Topic: 7080 Hyd couplersPosted: 21 Jun 2019 at 9:43pm |
This may be old news and everybody else has done it but I thought I would post anyway. The 7080 had been leaking through the coupler center part on 1 of them, quite a bit. Hey at least the sway block won't rust.
![]() ![]() Took it apart, thought maybe it was an O ring, of course not. The seal in the end is clamped into the unit when built. It's original # is Bruning CM-401F. Local parker dealer did not have any parts breakdown. Too late today to call Sandy Lake. Thought about it and I had some pioneer fittings for another project. Most of the male ends on the implements here are pioneer already. ![]() Took the new ones apart and they are the same diameter, just a little shorter. The top one is a dixon brand and the one I took apart is a pioneer unit. NOTE the check balls will fall out when you take that end cap off, UHH they went everywhere. ![]() Put the old end on so the snap ring would clip it on and the lever would work to release it. ![]() It fit on perfect, just a little shorter. ![]() I went ahead and did all 4 of them. The 4 pieces I had were 2 different numbers but they look identical. Parker #4050-4 and Dixon 18-400.
SteveM C/IL
Joined: 12 Sep 2009 Location: Shelbyville IL Points: 9264 |
Posted: 21 Jun 2019 at 9:59pm |
Man!....we must be related. That's the kinda thing I try to do. "I can fix this!"
IBWD MIke
Joined: 08 Apr 2012 Location: Newton Ia. Points: 4469 |
Posted: 22 Jun 2019 at 9:19am |
Sometimes the "I can fix this" is a curse! While I love to fix things, it sometimes leaves me in a perpetual state of 'fixing'.
SteveM C/IL
Posted: 22 Jun 2019 at 10:11am |
It is a curse! The time I've spent fixing VS replaceing is rediculess. Been ahead to spend the money and move on.
Unit3
Posted: 22 Jun 2019 at 12:45pm |
That is so cool. Great work and a job well done,,,,, but,,,,, now I have more someday projects to do. You maybe able to start your own small business with these then I can just buy new. 5 stars.
Edited by Unit3 - 22 Jun 2019 at 12:46pm |
