Print Page | Close Window
7080 Hyd couplers
Category: Allis Chalmers
Forum Name: Farm Equipment
URL: https://www.allischalmers.com/forum/forum_posts.asp?TID=162119
Printed Date: 17 Sep 2026 at 2:43pm
Topic: 7080 Hyd couplers
Posted By: LB0442
Subject: 7080 Hyd couplers
Date Posted: 21 Jun 2019 at 9:43pm
This may be old news and everybody else has done it but I thought I would post anyway.  The 7080 had been leaking through the coupler center part on 1 of them, quite a bit. Hey at least the sway block won't rust.
Took it apart, thought maybe it was an O ring, of course not.  The seal in the end is clamped into the unit when built.  It's original # is Bruning CM-401F.  Local parker dealer did not have any parts breakdown.  Too late today to call Sandy Lake.  Thought about it and I had some pioneer fittings for another project.  Most of the male ends on the implements here are pioneer already.
Took the new ones apart and they are the same diameter, just a little shorter.  The top one is a dixon brand and the one I took apart is a pioneer unit.  NOTE the check balls will fall out when you take that end cap off, UHH they went everywhere.
Put the old end on so the snap ring would clip it on and the lever would work to release it.
It fit on perfect, just a little shorter.
I went ahead and did all 4 of them.  The 4 pieces I had were 2 different numbers but they look identical.  Parker #4050-4 and Dixon 18-400.
Posted By: SteveM C/IL
Date Posted: 21 Jun 2019 at 9:59pm
Man!....we must be related. That's the kinda thing I try to do. "I can fix this!"
Posted By: IBWD MIke
Date Posted: 22 Jun 2019 at 9:19am
Sometimes the "I can fix this" is a curse! While I love to fix things, it sometimes leaves me in a perpetual state of 'fixing'.
Date Posted: 22 Jun 2019 at 10:11am
It is a curse! The time I've spent fixing  VS replaceing  is rediculess. Been ahead to spend the money and move on.
Posted By: Unit3
Date Posted: 22 Jun 2019 at 12:45pm
That is so cool. Great work and a job well done,,,,, but,,,,, now I have more someday projects to do. You maybe able to start your own small business with these then I can just buy new.  5 stars.
