6070-6080 dash
ac160 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac160 Quote  Post ReplyReply Direct Link To This Post Topic: 6070-6080 dash
    Posted: 13 Jun 2026 at 8:11am
Good morning.  My 6070  fuel gauge is not showing the right level of fuel in the tank and I need to test the gauge, but I can't get the dash panels off.  I have a couple of 6080s that I need to adjust the throttle friction blocks on as well.  From what I have found neither the operator's manual or the service manual mention how to remove the dash side panels.  I pulled the two bolts out of the side but they still seem to stuck at the top.   The service manual does explain a good way to test the gauges.
How do you get them off? It seems so simple, but I guess I am missing something.
AllisFreak MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AllisFreak MN Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jun 2026 at 8:26am
You have to carefully give them a tug but they do come off. They are bolted and also have a couple of pins behind them that kind of snap into place. I encountered the same question the first time I removed mine years ago.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac160 Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jun 2026 at 11:03am
Thank you. I was able to get them off.   So far testing has confirmed a bad gauge.
This page was generated in 0.039 seconds.
