4 bottom 16 verses 4 bottom 14 |
HudCo
Joined: 29 Jan 2013 Location: Plymouth Utah Points: 4225 |
Topic: 4 bottom 16 verses 4 bottom 14Posted: 28 Jun 2026 at 9:39pm |
how much differance would their be in the two differant size pulling them i am thinking a bout takeing two rollover plows and making a mounted four bottom with a tail wheel
Posted: 28 Jun 2026 at 9:47pm |
My math says 4 x 14's takes 56 HP to pull and 4 x 16's takes 64 HP. That also translates into a minimum weight of 5600 lb and 6400 lbs. This has been a formula I have used for years. Your results may vary with different soil types and the lay of the land.
Lars(wi)
Joined: 14 Sep 2009 Location: Permian Basin Points: 8560 |
Posted: 28 Jun 2026 at 11:40pm |
Wouldn’t it be cheaper, by the time it’s all said and done, to just buy a 4x16 plow? They sure don’t bring much at auctions these days. |
HudCo
Posted: 29 Jun 2026 at 8:17am |
frieght from the mid west ? thats the game changer
8070nc
Joined: 21 Mar 2019 Location: North Carolina Points: 898 |
Posted: 29 Jun 2026 at 9:03am |
If freight is a problem and time is not you might get a shipper to combine a load headed in your direction so everybody pays less. I did that one time. Luke in Wisconsin had a 7 bottom 3000 plow he had painted and put new tires on. It looked brand new. I had fantasized about one of those since i was a boy. I called him and asked if i paid him for it could he keep it until i could get it picked up. He said yes. I called a shipper i knew that worked the midwest a lot and he said let him work out a load and it wont cost that much. I think it was about a fourth of what it would have cost. May help may not your results wil varry
1984 80780
1957 D14 DES 300 with 25000 engine 616 tractor |
