210 injector leak
fastallis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote fastallis Quote  Post ReplyReply Direct Link To This Post Topic: 210 injector leak
    Posted: 16 Apr 2019 at 5:56pm
How do I fix this leak? it is not the return line.
Edited by fastallis - 17 Apr 2019 at 1:26am
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 16 Apr 2019 at 9:40pm
From picture, I can tell nothing. If it is leaking between adjusting nuts, there is a oring inside. If it is leaking at nut on drip tube, there is a rubber bushing in nut. If it is leaking where injector goes into head, replace the valve cover gasket.   MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 16 Apr 2019 at 11:03pm
LOL! Yeah,my bet is the cover gasket.Wink
Post Options Post Options   Thanks (0) Thanks(0)   Quote fastallis Quote  Post ReplyReply Direct Link To This Post Posted: 17 Apr 2019 at 1:31am
it is leaking at the blue line. It is diesel fuel.
injpumpEd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 17 Apr 2019 at 7:21am
Inj has to come apart to replace the oring inside. That isn't an original 210 injector. It will need reset once the adjusting nut it removed, and oring is replaced.
Post Options Post Options   Thanks (0) Thanks(0)   Quote fastallis Quote  Post ReplyReply Direct Link To This Post Posted: 20 Apr 2019 at 9:10am
Thanks Ed, I pulled the injector and took it to the neighbor who has a injector tester. He took it apart replaced the oring and set it at 3100 psi. I put it back in and no leaks. He seems to think those injectors are out of a 7000 series tractor. Why would someone have changed them from the originals? Any thoughts of why they would have changed them out?
bradley6874 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bradley6874 Quote  Post ReplyReply Direct Link To This Post Posted: 20 Apr 2019 at 9:29am
Being there not original I would pull the other five cuz you have no idea what they're set to now you got one correct and 5 maybe something else
This page was generated in 0.069 seconds.
