Wisc. DOT
DonDittmar View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DonDittmar Quote  Post ReplyReply Direct Link To This Post Posted: 18 Nov 2011 at 1:15pm
Originally posted by Dusty MI Dusty MI wrote:
I noticed, in several states, the Weigh Station warning signs state; "Commercial Vehicles".  If you ain't  . . . don't stop.
This is probably why RV's are exempt.
Dusty
That IS why RV's are exempt.
Tell me why an 85 year old my driving a 35ft diesel pusher with air brakes is ok, but a trucker driving a truck with the EXACT same system needs an endorsment.
There thought process is screwed up and it aint right.........
Edited by DonDittmar - 18 Nov 2011 at 1:15pm
1968 D15D,1962 D19D
Dipstick In View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dipstick In Quote  Post ReplyReply Direct Link To This Post Posted: 18 Nov 2011 at 6:43pm
Yeh,but headline news jump on truck accidents inna minute, whether or not it's a pickup or big truck, and give RV's a pass! When you become a professional truck driver with a CDL you give up your rights just like voting conservative.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 18 Nov 2011 at 6:44pm
The signs in Iowa say "All Trucks Over 6000 LBS Must Weigh". I know my pickup and trailer with a tractor on it are over 6K, but I've never stopped and never been chased down...
allisrutledge View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote allisrutledge Quote  Post ReplyReply Direct Link To This Post Posted: 18 Nov 2011 at 9:00pm
I got pulled over today in KY today by dot. I had a load of gates and coral panels. the officer was looking for a dot #. I told him the load was for my use and he let me go. I did have to explain to him that TN don't have ( farm) on the weighted plates.  I guess it was my lucky day, he didn't check anything else. Scott
Larry(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Larry(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 19 Nov 2011 at 8:00am
Nothing like a 80 year old husband and wife with the dog on the dash and a Jeep cherokee in tow behind a 45' diesel pusher running down the road and trying to manuver in town
'40 WC puller, '65 770 Ollie
*ALLIS EXPRESS contact*
I can explain it to you, BUT I cannot understand it for you!!
Dean/MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dean/MN Quote  Post ReplyReply Direct Link To This Post Posted: 19 Nov 2011 at 7:28pm
WI and MN are 10k. Best way to avoid them is to go on holidays when they are not around.
HD16,917H,185,7050,8030FWA,8050FWA
DaveKamp View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveKamp Quote  Post ReplyReply Direct Link To This Post Posted: 20 Nov 2011 at 11:05pm
Originally posted by DougS DougS wrote:
...A CGVWR (combined gross vehicle weight rating) which the GVWR of the truck AND the trailer is 26,001, with a trailer GVWR of 10,000 or greater, requires a Class A CDL.
...CDLs aside, if the scale sign says all vehicles weighing 10,000 pounds or more must stop, you had better stop.
the 26001lb threshold is universal and obvious... ANY time you're driving ANY vehicle, or combination, where rating exceeds 26001, EVEN IF you're much lighter, is at least a Class B (straight) or Class A (combination) requirement.  The other obvious, is if you have air brakes on either the tow vehicle, or the trailer... even if the tow vehicle has HYDRAULIC, and the trailer has AIR, you'll need the AIR endorsement AT LEAST, and a full Class A at most.  Typically, if you're driving a straight truck, no trailer, but air brakes, you'll need a B with airbrake endorsement.
The reason I stated it as-above-  Most states have a 'gotcha' situation with tow-vehicle GVW.  If the TOW VEHICLE's GVW is under 10k, this rule is an exception that allows you to tow ANY trailer (regardless of GVW), provided that you DO NOT EXCEED 26000.
That means that I can drive my 8400gvw pickup with a 28,000lb GVW trailer, as long as the combined WEIGHT of the truck (5300lbs) and trailer (7500lbs) and load (12000) are under 26001.
The catch being... there aren't too many 8400gvw pickups rated for a 19,500lb towing capacity...  and if they catch you doing that, you'll get pinched.
NOW... if your pickup has an 10,001 gvw, it doesn't matter WHAT you're doing, you cannot legally hook up a trailer that has a capacity greater than 15,999 without a Class A...  EVEN IF your truck is empty, and the trailer is empty... you're in violation.
WHY is it this way?
Easy.  It makes it legal for an individual or company to transport EMPTY TRAILERS legally with light-duty trucks.  You can legally move a 5-axle, 25000lb capacity boat trailer with a 1/2t pickup truck anywhere, without needing a CDL.
I cannot, however, hook ANY trailer to my company service truck (16k gvw) with capacity in excess of 10,000lbs... even if it's empty... hence, all our equipment trailers are rated for 9980lbs.  They're built to 14,400 spec for durability, but limited to 9980.
Now, the suggestion of farm exemptions vary from state to state, and many states (Wisconsin included) will determine your exemption based on your vehicle registration status.  It has been a few years, but last time I dealt with a WI Farm Exemption registration, they allowed Farm Exempt only on vehicles registered as FARM TRUCK.   More recently, I noticed that Minnesota has a registration technique for truck tags (and I cannot verify wether there's a distinction between commercial-duty vs. light-duty trucks), but heavy and medium truck tags identify the LISCENCED WEIGHT LIMIT for the truck INDEPENDANT of the truck's GVW.  I.E.  let's say you have a 5-axle dumptruck built and GVW-tagged for 72,000lbs (18k steer, two 10ks, and a pair of 17.5ks), you can LISCENCE it for 50,000.  Advantage being, you work in a vicinity where bridge and road restrictions all indicate LISCENSED WEIGHT 25T...  and you want the extra two axles to help transport lime into soft fields without sinking in... you can do so, without paying the much more expensive 72k weight limit that you'll never need.  The point here, is that some states' rules are applicable not so much to the VEHICLE GVW, but the LISCENSED WEIGHT.  Federal is one thing, STATE is another.
Regardless of the exemption status, trucks so-registered were still required to stop at state weigh stations, and the exemption status was not granted automatic reciprocity to Minnesota... getting waived for reciprocity was a function of the traffic court... meaning, post-facto... which meant you would've probably been hauled in for other violations as well.
Don't think that vehicles labeled 'non-commercial' are given automatic waiver.  Any vehicle over the specified weight are expected to stop.  Wether or not they come after you for ignoring is simply a matter of your luck.  The STATE DOT has absolute jurisdiction, regardless of your label, to take enforcement action, and yes, they can do so with a family of five in a station wagon pulling a camper.  It's just that they rarely do.
There IS reason to be concerned about transporting materials or equipement for others, but the challenge of it, is wether you're doing it FOR HIRE.  I can, for example, transport property belonging to someone else, and I don't need a DOT number to do so, so long as it isn't something I'm doing as regular business.  The requirement key phrase is 'In Interstate Commerce'.  The last word... Commerce... you're either transporting things for purpose of THE BUSINESS OF buying or selling, or you're transporting things as a SERVICE-ORIENTED-BUSINESS.  What that boils down to, is that you are not required to have a FEDERAL DOT registration number just to pull your own tractors around.  If you're buying and selling tractor or parts as a commercial enterprise (for example, buying at auction, and parting 'em out), and CROSSING STATE LINES to either pick up, or deliver that which you've bought and/or sold as your business, you'll need the Federal DOT number.
Gotcha:  SOME STATES have their OWN requirements.  Kentucky is an example of a STATE which has it's own set of IN_STATE commercial rules, so be careful there.
Finally, Ill concur that it's always easier to ask forgiveness than permission.  Typically, if you bypass a scale, and the officer comes after you, it can be solved by just paying the fine.  Last time one of my cohorts dealt with the situation, it was only about $1700... no big deal.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveKamp Quote  Post ReplyReply Direct Link To This Post Posted: 20 Nov 2011 at 11:14pm
And as for the 'if you ain't, don't stop' issue...  I have driven my company truck, AND my private truck, through weigh stations.  I've been 'called in' to bring my logbook, liscense, registration, and proof-of-insurance in BOTH scenarios.
I've also been waved through... never even bothered to weigh me.
I've only been 'barked at' once, for coming in when they said 'I didn't need to'.  My answer "Well, I was't sure- better safe than sorry".
One of the reasons why it's not wise to bypass, is because SOME STATES... short list off the top of my head... New Mexico, Utah, and Arizona require you to purchase a ONE_TIME TRIP permit.  Nevada (which has no weigh stations) requires you to CALL AHEAD to purchase a TEMPORARY REGISTRATION.  These are not necessarily keyed to your status as a commercial or non-commercial entity.  Realize, however, that these states do this as administrative function of a LEGISLATED LAW (not a federal or state regulation)... oftentimes, it's under the guise of a 'fuel' or 'road use' tax.  If they're having a 'bad day', you'll find them putting a stethoscope up your tailpipe for being ignorant.    The rules tend to change without being obvious to the average person, so I find it's best, under all situations, to feign ignorance AT the station, than two miles' past with blue lights in the rear-view mirror.  Most of the time, if you ask 'em "Hey- is there anything I need to know, or do, to do this?", they pretty amicable about getting it straightened out without tears.
DougS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougS Quote  Post ReplyReply Direct Link To This Post Posted: 21 Nov 2011 at 7:49am
Dave... note the "R" in GVWR.  They need to know this means "rating."  Even if they aren't hauling 26,001 pounds, the license requirement applies if the vehicle or vehicle combination is rated to haul 26,001.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveKamp Quote  Post ReplyReply Direct Link To This Post Posted: 21 Nov 2011 at 9:14am
You're absolutely right, Doug- a driver NEEDS to recognize each instance of the rules, and that there's a difference in scrutiny for the WEIGHT of a vehicle, it's RATING (for each axle, for the total vehicle, and for the total combination), and the vehicle's LISCENSURE.  Re-noting the point above-  the need for CDL in MOST SITUATIONS, is irrelevant to what you actually weigh... it's what your vehicle COMBINATION is RATED for.
There's one more 'gotcha' that I occasionally recieve calls about, which doesn't directly involve the original question of the thread, but one that people SHOULD be aware of:
  A driver has a truck loaded to within legal limits for his truck, and within legal limits of his liscensure, and within the legal limitations of the highway rules:
Steer axle:  11,780
Drive axle:  33,920
Trailer axle: 33,160
Gross:  78860
But still cited for being over on steers.  Why?
Because the truck's steer-axle is fitted with tires rated for 5200lbs each, not 6000lbs.
This scenario doesn't frequently happen to big commerical trucks, but it DOES happen.  I am noting this, because it happens MOST FREQUENTLY to individuals hauling private loads.  It happens because someone has a trailer that needs new tires, so they install a set that they've purchased, and not READ THE SIDEWALL.  There's nothing illegal about running a 1400lb capacity tire on an axle rated for 3500lbs- people frequently do this to save money, recycle good-used car tires, and get a smoother ride, but if you do this on a tandem-axle trailer rated for 7000lbs, but you can't load the trailer past 5600lbs.  If the trailer weighs 2500lbs, you can't carry more than 3100lbs on the trailer.
There's many other rules that often don't affect a guy pulling a tractor home... many urban areas have length, height, and turning-radius regulations to prevent trucks from hitting the insides of archways under highway bridges and tunnels.  California has some crazy rules about distances between the hitching point and trailer axles.  MOST of the US have rules that allow tandem-axles spaced out greater than some distance (some states, 8' spread, some states it's 10') to be calculated as a single axle (typically 20,000lb per axle) while axles closer than that distance are considered 'multi-axle' group, and restricted to a lighter limit by virtue of the group (17,500 per axle).  The reason for these caveats, is because longer axle-spacing distributes the rolling load over a greater expanse of pavement, hence less damage to roadways.  The advantage to running a spread-axle trailer means that a driver can carry more on his trailer (40,000 between the two rather than 34,000) and carry less weight on the hitch of his truck.  When carrying a load that's predominantly heavier on one end, that end can be placed towards the rear, which does great things for carrying difficult-to-balance loads.  Unfortunately, western provences of Canada apparently now have a rule that doesn't allow spread-axle trailers.  I have no idea what the reasoning is, but it has been suggested to me frequently that this 'rule' is a way of forcing loads to be moved from US trucks onto Canadian trucks, essentially defeating NAFTA provisions in favor of Canadian labor.  Wether that's true, I have no idea, but I have found no other 'physical reason' why the 'rule barrier' exists here.
This page was generated in 0.081 seconds.
