Wd45 using oil?
Allis-chalmers wd45 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis-chalmers wd45 Quote  Post ReplyReply Direct Link To This Post Topic: Wd45 using oil?
    Posted: 22 Apr 2012 at 9:43am
It seems that since I bought the tractor the oil had never been changed.. There was so much sludge and crap built up int the engine . So I cleaned what I could out and changed the oil and filter and it seems like its using oil and my pressure is very low, it leaks out around the oils pressur guage port into the engine . What should I do? What could it be?
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 22 Apr 2012 at 9:55am
j.w.freck View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote j.w.freck Quote  Post ReplyReply Direct Link To This Post Posted: 22 Apr 2012 at 7:04pm
if you check real close you will more than likely find it cracked.need to remove it to ck.
