Print Page | Close Window
Wd45 using oil?
Category: Allis Chalmers
Forum Name: Farm Equipment
URL: https://www.allischalmers.com/forum/forum_posts.asp?TID=49401
Printed Date: 24 Aug 2025 at 2:39am
Topic: Wd45 using oil?
Posted By: Allis-chalmers wd45
Subject: Wd45 using oil?
Date Posted: 22 Apr 2012 at 9:43am
It seems that since I bought the tractor the oil had never been changed.. There was so much sludge and crap built up int the engine . So I cleaned what I could out and changed the oil and filter and it seems like its using oil and my pressure is very low, it leaks out around the oils pressur guage port into the engine . What should I do? What could it be?
Posted By: CTuckerNWIL
Date Posted: 22 Apr 2012 at 9:55am
Tighten the fitting where it leaks.
http://www.allischalmers.com/forum/forum_posts.asp?TID=49321&title=wd45-oil-pressure" rel="nofollow - http://www.allischalmers.com/forum/forum_posts.asp?TID=49321&title=wd45-oil-pressure
Posted By: j.w.freck
Date Posted: 22 Apr 2012 at 7:04pm
if you check real close you will more than likely find it cracked.need to remove it to ck.
