WD Leroi?
Les Kerf View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Les Kerf Quote  Post ReplyReply Direct Link To This Post Topic: WD Leroi?
    Posted: 01 Jul 2026 at 11:01pm
Went with Grandson to look at a WD for sale, turns out it has a Leroi engine Confused It starts right up and runs nice, both clutches work correctly, brakes need work (no surprise there), transmission seems tight, good tires all around.
Grandson wants to buy it (it's his money he earned haying), the only reservation I have is the Leroi engine. Is that something to avoid or is it no big deal?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jul 2026 at 6:38am
If it is a tractor that has to "work" to earn its keep, when it comes time to overhaul it, I am told crankshaft main bearings may no longer be available. They are different than what AC used.
powertech84 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote powertech84 Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jul 2026 at 8:44pm
I have a Leroi 201 in a gehl chopper. When I overhauled it I used a wd kit. Everything worked. The only difference i saw in the whole engine with what allis used was the Leroi rods had a floating piston pin.
This page was generated in 0.234 seconds.
