Truck oil change |
ACinSC
Joined: 16 Dec 2015 Location: South Carolina Points: 3406 |
Topic: Truck oil changePosted: 06 Oct 2026 at 5:55am |
Did my truck yesterday
I'm 73 and had both knees replaced. Plan to keep doing my own oil changes as long as I can, but I'm beginning to think it won't be much longer. Any thoughts? Thanks |
sho-man1
Silver Level Access
Joined: 14 Sep 2009 Location: Wylie, TX Points: 200 |
Posted: 06 Oct 2026 at 7:00am |
I like to use the shop vac for assistance when pulling the oil pan drain plug.
I place the catch pan under the drain plug, loosen the plug, place the shop-vac pickup hose onto the oil fill port on the valve cover, turn the vac on. Remove the drain plug then shut the vacuum off. Hands get no oil on them and no splash into the catch pan. The Ford 7.3 has over 15 quarts of oil, so I don't like to spill any.
Posted: 06 Oct 2026 at 8:57am |
Four post hoist. Drive vehicle on. Raise up. Drain oil and change filter. Let down and fill with oil. Never have to bend over or get down on your knees. Problem solved.
Joined: 11 Sep 2009 Location: illinois Points: 93505 |
Posted: 06 Oct 2026 at 9:09am |
i still do the truck and car at 73 years old... Got both original knees ... but YES, it is begining to be a chore to "get back up" when you laying on the ground..
JW in MO
Joined: 16 Feb 2010 Location: Mid Central MO Points: 2751 |
Posted: 06 Oct 2026 at 10:19am |
I'm 69, still do my truck, all original parts, however, left knee and hip aren't as limber as before. Send the wife to the dealership with her car, too low to the ground, even on ramps, and I'm out of the crosshairs if it isn't done in her timeframe.
ACinSC
Posted: 06 Oct 2026 at 10:32am |
15 quarts! That's a lot, good idea with the shop vac. My truck holds 8 quarts. Dr Allis,a lift sure would be sweet. Thanks guys
Les Kerf
Posted: 06 Oct 2026 at 11:00am |
I have been installing Fumoto quick drain valves on my vehicles; they don't help with the problem of old age and bad knees but they do minimize the time and effort underneath the rig. Plus, I can slip a hose over the valve and direct the stream to reduce splashing. I like to drain the oil while hot and let it drip over night. |
DMiller
Joined: 14 Sep 2009 Location: Hermann, Mo Points: 36766 |
Posted: 06 Oct 2026 at 11:50am |
Our KW I equipped with Quick Drains, flip a Locking handle and it Drains, my old 7.3 also 15 quarts I can still access under I also change as do the Deere 2305 and my 180. Old Impala, Tire shop with Post Lift, tires rotation inspect brakes and oil change cheap as to mess! Wife’s Explorer same shop. He had a Clients SUV in the other day, adds 1/2hr charge to Drop the Splash Pan to access engine, new crap, NOT buying!!
plummerscarin
Posted: 06 Oct 2026 at 11:52am |
YEP!! No regrets getting one. Add to that a catch can on wheels to roll under the drain plug, raise the funnel and no mess. The can has an air fitting so I can pressurize it to unload into my cousins waste oil furnace barrel |
Hubert (Ga)engine7
Joined: 12 Sep 2009 Location: Jackson Cnty,GA Points: 6694 |
Posted: 06 Oct 2026 at 12:16pm |
That is the way to go if you are doing your own oil changes or doing it for others. Wish I had a place here where I could put in a lift. Since I am old, fat and lazy I have been taking my vehicles to the local tire shop for a number of years. I furnish the oil and filter and they do the labor along with checking the brakes and tires.
ACinSC
Posted: 06 Oct 2026 at 12:21pm |
Looks like a good idea Les. I did crawl under my truck only to realize I'd left the plug on my bench !! Thanks guys
Kenny L.
Posted: 06 Oct 2026 at 2:01pm |
Grandson does my oil changes on the lawn mowers, tractors and the pickup, but mamas goes to the dealership.
DiyDave
Joined: 11 Sep 2009 Location: Gambrills, MD Points: 56158 |
Posted: 06 Oct 2026 at 3:24pm |
I do mine with a oil sucker, like they use on boats. It goes in through the dipstick, you don't have to pull the plug, there's generally only 1/2 cup or so left in the pan. Every other change, I do take the plug out, just to get it all out, once in a while...
WF owner
Joined: 12 May 2013 Location: Bombay NY Points: 5328 |
Posted: 07 Oct 2026 at 6:08am |
I use a couple of the ideas above.
When I built my garage, my son-in-law talked me into building it with 16' ceilings and buying a lift. I poured the concrete in preparation for a two-post lift that I found online. (I had first thought about a pit, but my insurance company said they would cancel my insurance if I put in a pit.) When I went to pick up the two post lift, the guy who was working in the business noticed my dually diesel pickup. He told me the arms on a 9000 lb. two-post lift were not heavy enough to support a diesel and I should go to a (much more expensive) 12,000 lb. lift. He asked me what I was going to do with the lift and recommended an extra-long, extra-wide and extra-tall 9,000 four post lift. He was quick to point out that vehicles do fall off two-post lifts. I bought the four-post he recommended, along with a rolling jack and have never regretted it. Like Les, I have used Fumoto valves in all my vehicles for over 20 years. A local big truck repair owner told me that every truck he does the maintenance on gets a Fumoto valve installed. He said some of his mechanics tend to overtighten oil drain plugs and after paying to replace some oil pans on big trucks, they decided to go to Fumoto valves on everything. The ones I buy has a nipple for a plastic hose, so I have no spillage from the drain plug (I wish I could say that about the oil filter). They are relatively inexpensive and make draining oil much cleaner and easier.
ACinSC
Posted: 07 Oct 2026 at 6:42am |
Lots of good info. Thanks guys!
Ed (Ont)
Joined: 08 Nov 2009 Location: New Lowell, Ont Points: 1676 |
Posted: 07 Oct 2026 at 6:57pm |
I do most of my work on a 2 post hoist. But the biggest I can accommodate is a 2500 truck. I find the 2 post better for most jobs but a little harder to set up on hoist. I use 4 poster mainly for storage in winter. Car on top and 1 underneath.
Ed (Ont)
Posted: 08 Oct 2026 at 7:14am |
This is a 10,000 lb hoist. Lifts the truck well. If I were to get another 2-post I would get a 12k. Truck is just under 8,000 lbs. There are lots of 10k hoists available that are a bit beefier as well.
Edited by Ed (Ont) - 08 Oct 2026 at 7:24am |
Ed (Ont)
Posted: 10 Oct 2026 at 4:28pm |
Have to fold mirrors to get it in place!!
