Truck oil change
ACinSC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACinSC Quote  Post ReplyReply Direct Link To This Post Topic: Truck oil change
    Posted: 1 hour 32 minutes ago at 5:55am
Did my truck yesterday
I'm 73 and had both knees replaced. Plan to keep doing my own oil changes as long as I can, but I'm beginning to think it won't be much longer. Any thoughts? Thanks
sho-man1 View Drop Down
Bronze Level Access
Bronze Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote sho-man1 Quote  Post ReplyReply Direct Link To This Post Posted: 27 minutes ago at 7:00am
I like to use the shop vac for assistance when pulling the oil pan drain plug.
I place the catch pan under the drain plug, loosen the plug, place the shop-vac pickup hose onto the oil fill port on the valve cover, turn the vac on. Remove the drain plug then shut the vacuum off. Hands get no oil on them and no splash into the catch pan.  The Ford 7.3 has over 15 quarts of oil, so I don't like to spill any.
