couple more wc carb questions...
Glockhead SWMI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Glockhead SWMI Quote  Post ReplyReply Direct Link To This Post Topic: couple more wc carb questions...
    Posted: 29 Sep 2012 at 9:40pm
So I tore into my wc 7078c carb tonight. I have a couple questions. I believe it is the idle jet that has problems. I can not get carb cleaner or compressed air to pass through it. The one end of the jet is sealed. Is that normal? it has one other hole in the side close to where it screws in.
Also, near the idle air screw, there appears to be an air bleed that goes through the throat of the carb and terminates right above the throttle plate. Should that be clear as well?
I'll post pics tomorrow as I'm sure a picture will be better than my horrible description. Hope it runs tomorrow.
acwdwcman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote acwdwcman Quote  Post ReplyReply Direct Link To This Post Posted: 01 Oct 2012 at 8:39am
yes a picture would help
wd with a freeman model 90 trip loader, wd45, 38 unstylled wc, b 10 garden tractor and 2-14 ac trip plow. grandpa has a 56 wd45. wd. allis chalmers snap coupler blade and 3 bottom snap coupler plow
Post Options Post Options   Thanks (0) Thanks(0)   Quote Glockhead SWMI Quote  Post ReplyReply Direct Link To This Post Posted: 01 Oct 2012 at 9:40am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Glockhead SWMI Quote  Post ReplyReply Direct Link To This Post Posted: 01 Oct 2012 at 9:46am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Glockhead SWMI Quote  Post ReplyReply Direct Link To This Post Posted: 01 Oct 2012 at 9:51am
This is the jet. The tube is sealed at the top.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Glockhead SWMI Quote  Post ReplyReply Direct Link To This Post Posted: 01 Oct 2012 at 8:38pm
Hope to have this running this weekend.
