Riding Mower Question
Rick ONU View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rick ONU Quote  Post ReplyReply Direct Link To This Post Topic: Riding Mower Question
    Posted: 30 Apr 2012 at 12:13pm
Hey everyone.  I'm new here and this is my first post.  Not too mechanically inclined, but I'm learning something new every chance I get.  I took the blades off of the deck of my Deutz Allis 1616 to sharpen them.  I put them back on in the exact same place, but now when I engage the PTO I can hear the blades striking each other occasionally (every 3-4 seconds).  I have adjusted just about everything I can think of and still no luck.  I was wondering if anyone had any suggestions on how to fix this issue???
Brian F(IL) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian F(IL) Quote  Post ReplyReply Direct Link To This Post Posted: 30 Apr 2012 at 12:50pm
Welcome to the Forum.
Double check to make sure each blade is centered in the arbor shaft.  Also double check to make sure one of them isn't put on upside down.  I've been there before myself.
Stan IL&TN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stan IL&TN Quote  Post ReplyReply Direct Link To This Post Posted: 30 Apr 2012 at 3:57pm
+1 what Brian said.
Only other thing it could be is that one of them is slightly bent and you put it back on in another location from where it was.  Most likly one is not centered or on upside down.
1957 WD45 dad's first AC
1968 one-seventy
1956 F40 Ferguson
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rick ONU Quote  Post ReplyReply Direct Link To This Post Posted: 01 May 2012 at 10:24am
Thanks for the input fellas!
Dave in il View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave in il Quote  Post ReplyReply Direct Link To This Post Posted: 01 May 2012 at 6:11pm
I doubt it could be this simple but look to see if the blades hit when you turn them by hand, if they do then move one of the blades (slip the belt) and see if the blades hit when you turn them again. It may be the blades are timed so they hit.
AGCO My Allis Gleaner Company
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 01 May 2012 at 8:33pm
If this is a 3 blade deck, the front blade may be shorter than the 2 side blades so if the short blade isn't in the front center position they will hit .  All overlapping blades I have seen have a timing belt to run them so they can not get out of time without the belt jumping a cog.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 01 May 2012 at 11:06pm
+1 on check your blade length. If there is an odd length blade, put it on the middle spindle.
