D17 PS question
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Topic: D17 PS question
    Posted: 15 Apr 2012 at 6:30pm
Must I remove the radiator to access the pump discharge tube connection at the lower left?
Edited by CTuckerNWIL - 15 Apr 2012 at 6:32pm
Orange Blood View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Orange Blood Quote  Post ReplyReply Direct Link To This Post Posted: 15 Apr 2012 at 9:09pm
Unless I am missing something, NO.  I can get to that fitting, and did on mine this past winter, when rebuilding my front end.
Still in use:
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 15 Apr 2012 at 9:21pm
Rad does not need to come off.  Get the line from under the tractor.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 15 Apr 2012 at 10:23pm
There is a tin "pan" that covers the bottom and I couldn't see what holds it up. Thought maybe it was welded in there.
ironac View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ironac Quote  Post ReplyReply Direct Link To This Post Posted: 16 Apr 2012 at 12:21am
I need that line. Mines twisted a shot
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 16 Apr 2012 at 6:36pm
So is my 17 the only one with this pan under the pedestal?
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 16 Apr 2012 at 6:38pm
If I can get to mine and find it needs replaced, I may make up a new one. If that happens and it works, I make a couple extra.
Don(MO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 16 Apr 2012 at 7:13pm
Hey Charlie is this D17 a wide-front or n-front tractor? The n-front's have a mud shield below the front end.
Don
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 16 Apr 2012 at 7:15pm
Narrow front. Can the shield be take off from underneath?Don, you may have seen the tractor. It came from a little North West of you.
Edited by CTuckerNWIL - 16 Apr 2012 at 7:16pm
Charlie175 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 16 Apr 2012 at 7:16pm
Narrow fronts have the mud pan
Charlie
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 16 Apr 2012 at 7:20pm
Charlie the pan is heald on with four bolts, you can get to them from the bottom side' and there's a plug on the right side too. If the mind is working right. lol
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 16 Apr 2012 at 8:54pm
Thanks Don. Guess I'll pull it outta the dirt floor shed and on to some green grass to lay in:)
