417 Loader question?
1953CA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 1953CA Quote  Post ReplyReply Direct Link To This Post Topic: 417 Loader question?
    Posted: 21 Mar 2012 at 12:09pm
Will a 417 loader from a D17 series IV fit on a D15 Series II or are the mounting brackets different?  And how much are they worth?
Andrew
1945 AllisCletrac / 1948 "B" / 1953 "CA" / 1955 "WD-45" / 1963 "D-15 Series II"
"No Air Support without Ground Support"
Gary View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Quote  Post ReplyReply Direct Link To This Post Posted: 21 Mar 2012 at 4:39pm
If it is an original Allis loader on a Series IV, it is more apt to be the 500 series;
no front pump, no oil reservoir in loader frame, no hydraulic control valves on loader boom.
Gary
Post Options Post Options   Thanks (0) Thanks(0)   Quote 1953CA Quote  Post ReplyReply Direct Link To This Post Posted: 21 Mar 2012 at 5:23pm
It has a 417 sticker on it, and no front pump or controls which was run off the D-17.  Reservoir is in the left up-right.  So without the controls and front pump, what would it be worth?
Gary View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Quote  Post ReplyReply Direct Link To This Post Posted: 21 Mar 2012 at 5:33pm
If  in decent shape  with no weld patches etc, around 800 to 1,000.
To mount on a D-15 ( if it will fit ) you will need the front mounted pump
and  two double acting hydraulic valves and all necessary hoses.
Gary
Post Options Post Options   Thanks (0) Thanks(0)   Quote 1953CA Quote  Post ReplyReply Direct Link To This Post Posted: 21 Mar 2012 at 11:38pm
I see now that a 415 will fit a D-15, mounting brackets are different.  Would anyone be interested in a 417 loader for a D-17???
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 22 Mar 2012 at 8:28am
I would if it wasn't too far out of my area in NW IllinoisSmile
This page was generated in 0.083 seconds.
