Unstyled WF manifold gasket needed...
Chad(WI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chad(WI) Quote  Post ReplyReply Direct Link To This Post Topic: Unstyled WF manifold gasket needed...
    Posted: 25 Dec 2011 at 10:01am
Anyone know of a source for the gasket that goes between the exhaust cover stamped "G" and a sideshooter manifold itself, or has anyone had luck making it out of a heavier gasket material? Any thoughts or info appreciated.
JoeM(GA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoeM(GA) Quote  Post ReplyReply Direct Link To This Post Posted: 25 Dec 2011 at 10:08am
Chad, there is no gasket there. I had the one on my WC just barely decked so it would be very flat and then cut one out of some very thin muffler gasket material
Allis Express North Georgia
41 WC,48 UC Cane,7-G's,
Ford 345C TLB
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chad(WI) Quote  Post ReplyReply Direct Link To This Post Posted: 25 Dec 2011 at 4:17pm
Thanks Joe....good reason why I didn't see one listed in the parts book.
hamman01 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote hamman01 Quote  Post ReplyReply Direct Link To This Post Posted: 28 Dec 2011 at 7:11pm
I have seen guys use sheet copper to make gaskets for exhaust out of. A couple layers of that in between the cover or 45 deg. stack should do it.
