WD snap coupler release chain
Orange Tractors View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Orange Tractors Quote  Post ReplyReply Direct Link To This Post Topic: WD snap coupler release chain
    Posted: 08 Sep 2011 at 11:29am
What is the best way to replace the release chain from the lever to the bell? My chain has some stretched links and I have tried everything I can think of to get it adjusted to work properly. I can get it to latch, but then the chain is too loose to move the hook enogh to easily release. If I set it to release the hook, the chain is too tight and the hook will let go under load.
It is not fun live testing release latches while plowing.
Thanks for the help,
Robert
Murph-NC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Murph-NC Quote  Post ReplyReply Direct Link To This Post Posted: 08 Sep 2011 at 11:49am
I can't help with your question, but I'd suggest adding a safety chain to your plow to prevent a serious injury in case the latch releases again while plowing.
'41 C w/Woods L503 mower, #3 mower, 2-way plows for C
John (C-IL) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote John (C-IL) Quote  Post ReplyReply Direct Link To This Post Posted: 08 Sep 2011 at 12:10pm
Hopefully this picture will help.
Dave in il View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave in il Quote  Post ReplyReply Direct Link To This Post Posted: 08 Sep 2011 at 12:25pm
On my 45 the lever is connected to the second link, I would guess it's how someone shortened the chain.
Gary(MO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 08 Sep 2011 at 3:28pm
Where is the best place to find this type of release chain? My 45 needs new chain and Orchlein stores don't carry it. Thanks Gary
Bob D. (La) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bob D. (La) Quote  Post ReplyReply Direct Link To This Post Posted: 08 Sep 2011 at 5:47pm
I just bought some down here at TSC a couple weeks back. HTH
Post Options Post Options   Thanks (0) Thanks(0)   Quote Orange Tractors Quote  Post ReplyReply Direct Link To This Post Posted: 08 Sep 2011 at 7:16pm
Murph-NC, I have been giving that some thought, seeing a 3-14 plow rise up behind you will certainly get the heart rate up.
John (C-IL) That is the way I have mine routed.
Gary(MO) I don't know where you are in MO, but I bought some chain that at least looks right at the Family Center in Butler.
Thanks for the help guys; when the snap coupler system is working right, I can hook up my plow without getting off the tractor. My blade isn't quite so easy, but it still beats horsing around on 3 pt implements when you are by yourself.
Robert
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 08 Sep 2011 at 8:30pm
O.C.  I am on east side of state but I am close to a TSC. I will try there. Thanks Gary
MBwcIll View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MBwcIll Quote  Post ReplyReply Direct Link To This Post Posted: 08 Sep 2011 at 8:35pm
I got some at my local Midland Farm & Home store.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 08 Sep 2011 at 9:26pm
Robert
You might check out the snap bell real close for wear. Any pivot points or the latch itself can wear causing problems like you are having.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Orange Tractors Quote  Post ReplyReply Direct Link To This Post Posted: 09 Sep 2011 at 7:53pm
Robert
Thanks, I'll do that. The snap coupler parts came off of a well worn parts tractor.
I have been thinking about going back to using the pin hitch that Grandpa always used.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 09 Sep 2011 at 8:14pm
That might be the safest thing you could do. There is a replacement spring available somewhere for the latch on the bell also. They can get weak or break and cause a forward force on the back of the seat.
 So since this was converted, do you use the latches on the lift arms. The latches are supposed to release if the bell comes unhooked.  This is what happens using bolts or pins on the lift arms with a snap couple bell.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Orange Tractors Quote  Post ReplyReply Direct Link To This Post Posted: 10 Sep 2011 at 11:51am
Yes Sir, I use the Lift latches, and mine released the plow when the rear bottom got about four feet out of the ground, I was stomping the clutch, closing the throttle and ducking forward all at the same time.
I don't know why, but Grandpa had a snap coupler plow that he hitched underneath the tractor with what looks to me like a factory flat clevis and pin. He also had lift latches on the lifting arms.
Unfortunately, after Grandpa went to the nursing home, some lowlife stole the lift latches, generator, and dash off the tractor before I retired from the Navy.
I bought a parts tractor because I also needed a manifold, and one rear wheel.
The snap coupler bell was just a bonus. Before I start plowing this fall I will take it apart and inspect everything again.
Robert
This page was generated in 0.178 seconds.
