180, 3 point lift creeps up?
nsula_country View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote nsula_country Quote  Post ReplyReply Direct Link To This Post Topic: 180, 3 point lift creeps up?
    Posted: 15 Jun 2011 at 11:13pm
I have noticed when mowing the 3 point lift creeps up. The cylinders leak a little out the vents when parked, but I have kits for them. If they were an issue they would creep down. Could it be my valve is not centering properly? Can the centering detent be adjusted. Is the valve worn?
Thanks,
CT
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jun 2011 at 6:28am
Traction booster linkage needs adjusted or linkage at valve is sticking.  MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote nsula_country Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jun 2011 at 8:19am
All the linkages from the "torque" link where the base of the lift arms are to the traction control levers themselves are gone. those two short levers are decoration. I'd like to repair that some day. I'd like the draft control to work again.
The handle seems stiff in places like the detent or linkage is sticking. I'll check into that. I'm thinking valve.
CT
