What kind of rivet is this?
TomYaz View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TomYaz Quote  Post ReplyReply Direct Link To This Post Topic: What kind of rivet is this?
    Posted: 05 Jun 2011 at 7:24pm
This style of rivet seems a lot stronger than your typical pop rivet. What is the name of this kind of rivet and they even available anymore?:
TMiller/NC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TMiller/NC Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jun 2011 at 7:39pm
Check McMaster Carr they have them.  Countersunk head tubular, same as brake lining rivet ...Tim
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jun 2011 at 7:53pm
Proper term s a cold upset rivet, with that one having a "elevator" head(flat and almost flush)
Toscani NE SD View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Toscani NE SD Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jun 2011 at 9:10pm
i don't know how to spell it properly ,but it's a huck rivet,semi's use them ,
LouSWPA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LouSWPA Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jun 2011 at 9:12pm
Looks like one would need a special tool to set them
I am still confident of this;
Wait for the Lord;
SHAMELESS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SHAMELESS Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jun 2011 at 11:48pm
any rivit...is a pain in the butt rivit!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jun 2011 at 11:53pm
Yes you need a setting tool for them , either a driver or press. Used a similar one for brake linings and I used similar on circuit boards where multi-layer or 2 sided boards needed contact on both side .
