How to with WD Cultivator
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted J Quote  Post ReplyReply Direct Link To This Post Topic: How to with WD Cultivator
    Posted: 08 Dec 2010 at 12:33pm
How do the forward sections on a WD cultivator go up and down?  I just bought a set of fronts and rears for my WD45 and there is nothing to make the forward sections move.  They are wired in place in fact.  Any pictures out there?  Any help is sure appreciated.  Thanks, Ted
Dans 7080 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dans 7080 Quote  Post ReplyReply Direct Link To This Post Posted: 08 Dec 2010 at 12:43pm
There is a way to unhook one of the rear hydraulic cylinders and it flipps around to raise  them, then there is a valve on the pump that you have to change to set it to delayed lift. Im not exactly sure how to do it, but this should give you a start.
skipwelte View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote skipwelte Quote  Post ReplyReply Direct Link To This Post Posted: 08 Dec 2010 at 12:48pm
there is a backet that mounts on the tractor frame under the gas tank and two steel rods and go fromt he bracket linkage to the cult gangs.  You need that bracket and steel rods.    An operators manual will show you exactly how to do it.  HTH
Steve M C/IL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve M C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 08 Dec 2010 at 1:14pm
left cyl unpin at lift arm,swing foward pin to lift bracket
monitordoc View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote monitordoc Quote  Post ReplyReply Direct Link To This Post Posted: 08 Dec 2010 at 2:22pm
 I HAVE A 2 ROW CULTIVATOR FOR A WD/WD45 WITH ALL OF THE MOUNTING BRAKETS AND LIFT LINKAGE.  INTRESTED??
WD,D17-S4,180,D21
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted J Quote  Post ReplyReply Direct Link To This Post Posted: 08 Dec 2010 at 2:26pm
I sent you a PM
Bill Long View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill Long Quote  Post ReplyReply Direct Link To This Post Posted: 08 Dec 2010 at 2:28pm
The hyd setting is A screw at bottom of pump screw into detent in pump body, b screw to lock plates together making the hold position, and c screw at the front of the bottle top screwed in to provide delay between the front lift and the rear lift so tracks can be plowed.  If additional delay is needed then use the D screw in front of body.
The Hyd Ram linkage was described above.
Good Luck!
Bill long
KY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KY Quote  Post ReplyReply Direct Link To This Post Posted: 08 Dec 2010 at 2:35pm
I have pics of one mounted but I dont have a digital camera. Dont know of any other way to send one.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted J Quote  Post ReplyReply Direct Link To This Post Posted: 08 Dec 2010 at 2:43pm
Do you have a cell phone?  You can take pics with that and send them. I sent you my phone # in a PM.
