AC 170 , points and condenser
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Topic: AC 170 , points and condenser
    Posted: 12 Sep 2026 at 9:01am
What are the part numbers for these in Ecklin or Blue Streak or another good brand? What number plugs are you using, it has Champion N5C in it now.. I am away from farm, but wanted to take some with me next trip. Thanks, Tracy
JoeM(GA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoeM(GA) Quote  Post ReplyReply Direct Link To This Post Posted: 12 Sep 2026 at 10:09am
Tracy, these are Standard Ign / Blue Streak
Allis Express North Georgia
41 WC,48 UC Cane,7-G's,
Ford 345C TLB
ac45dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac45dave Quote  Post ReplyReply Direct Link To This Post Posted: 12 Sep 2026 at 10:31am
EchLin points CS763
EchLin con    RR174
    " cap.   RR145
    " rotor. RR301
    " dust cap RR164
Edited by ac45dave - 12 Sep 2026 at 10:51am
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 12 Sep 2026 at 6:15pm
It hardly matters what box you buy, the parts inside will most likely all be made at the same place. Champion plugs are about the worst quality plugs available today.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 12 Sep 2026 at 6:37pm
most of the BLUE STREAK stuff was made in Poland or Japan ... Assume it still is.... Not the same as China stuff..
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 12 Sep 2026 at 9:08pm
Joe, thanks a million! Tracy
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 12 Sep 2026 at 9:20pm
I went to the farm early. Tried to get plugs in town, no one had any. No help at parts stores. Filed the points and sanded them. Not a hat spark at plugs like I wanted after Cleaning rotarty button and cap. Weak to me. Sprayed choke cleaner into intake, never a pop at all. Just had put carb back on, floods again. When I had carb apart, cheched float and shutoff height. Both were good. Only ting I notice is float needle seems to want to hang in opening. Polished it best I could, still wants to hang. This is the most aggravating carb on any of the tractors I have, it is a Zenith. Before the alternator -regulator failure, it started and ran fine , but carb flooding could occassionaly happen. Always shut off fuel under tank when not running it. Going to try to put a cut off right before carb bowl. About at wits end with this one. What do you think? Thanks, Tracy
Gary Burnett View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Burnett Quote  Post ReplyReply Direct Link To This Post Posted: 12 Sep 2026 at 11:31pm
The steel tip needle valves are the only ones that always work right.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 13 Sep 2026 at 8:15am
how about the COIL ??  when they get old and weak, you can get a Minimal Spark Condition...
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 13 Sep 2026 at 9:41am
My float and needle does not have the little keeper spring. It has the viaton tip on it. Have not checked the coil. Have to order everything. Thanks, Tracy
Kenny L. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kenny L. Quote  Post ReplyReply Direct Link To This Post Posted: 13 Sep 2026 at 12:24pm
Tracy, if you would like I could fix you up with NOS tune up set. Kenny L.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 13 Sep 2026 at 6:50pm
Kenny, message sent. Thanks, Tracy
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kenny L. Quote  Post ReplyReply Direct Link To This Post Posted: 14 Sep 2026 at 12:39pm
Tracy, send you a PM
DaveKamp View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveKamp Quote  Post ReplyReply Direct Link To This Post Posted: 21 Sep 2026 at 10:48pm
The other thing to do... is run a wire from the battery directly to the coil, and another wire from the coil bracket to the battery negative.
It is not uncommon for a weak spark to be from an ignition or ground wire that's got enough corrosion hidden inside to limit current to the coil. Sometimes, the ignition SWITCH has a lousy contact... and sometimes, the battery ground wire is rotten right in the middle, such that when you attempt to crank the engine, the starter pulls basically everything the battery has to offer... save for what the ground cable will allow.
Plumbing, not Money, is the Root Of All Evil.
Wires are PLUMBING for Electrons, thus, evil.
Post Options Post Options   Thanks (1) Thanks(1)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 24 Sep 2026 at 7:27pm
Blue Streak tune up parts are made in Mexico not China.
