hardarti starting 8070
cowkicker View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cowkicker Quote  Post ReplyReply Direct Link To This Post Topic: hardarti starting 8070
    Posted: 02 Sep 2026 at 9:43pm
my 8070has always started verywell. it sat all winter and started right up this spring.  foward to now and now it acts like the inj pump looses its prime
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 02 Sep 2026 at 10:50pm
If it was mine, I'd probably replace the fuel hose that goes from the fuel filter on the left side of the tractor and crosses over under the water pump to the injection pump. That hose may be original and 44 years old.
8070nc View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8070nc Quote  Post ReplyReply Direct Link To This Post Posted: 03 Sep 2026 at 4:44am
You might want to replace the return hose that goes from the injection pump to the tank too. I had one doing the same thing. Started repacing hoses and when i changed that one it fixed it. I woundnt have thought the return would have caused it but it did on that one
1984 80780
1957 D14
DES 300 with 25000 engine
616 tractor
Kevin in WA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kevin in WA Quote  Post ReplyReply Direct Link To This Post Posted: 03 Sep 2026 at 4:48pm
Also check the return line drop tube in the tank, they have a habit of falling off, it has to be there or it will crank an extra 5 seconds or so after sitting overnight.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 04 Sep 2026 at 7:07am
Had one like that. Fall came and need primed if sat more than a day. PIA to operate that primer! Never diagnosed it cause it got an inline pump that winter
Fine since.
SilverShoes View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SilverShoes Quote  Post ReplyReply Direct Link To This Post Posted: 04 Sep 2026 at 6:44pm
Plunger in the primer might be leaking back
victoryallis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote victoryallis Quote  Post ReplyReply Direct Link To This Post Posted: 06 Sep 2026 at 10:03am
Experienced something similar on a 7060 and 7080. They don’t leak fuel out but let air in.
