hd 5 brake and clutch cleaning
Dobry Den Chip View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dobry Den Chip Quote  Post ReplyReply Direct Link To This Post Topic: hd 5 brake and clutch cleaning
    Posted: 14 Aug 2026 at 9:14am
I finally got both rear ends back together and have been driving around.  Steering is tough.  Clutches work but brakes do not.  Drained a little water and oil from each side.  Manual talks about using solvent to clean brakes and steering clutches.  What can I use as "solvent"?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 14 Aug 2026 at 1:27pm
First off do not leave the 3/4" pipe plugs in case bottom as oil and water drain from there
I installed plugs , then used diesel fuel to wash clutches and brake bands , couple gallons in each side , run machine operating clutches and brakes - then park and drain cases .
 I blocked clutch levers in pulled position to allow any fluid to drain from between plates
Since I changed to HD11 metallic rather then fiber clutch plates have not had to wash them .
