D14 "popping" when shut off
BOH View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BOH Quote  Post ReplyReply Direct Link To This Post Topic: D14 "popping" when shut off
    Posted: 03 Aug 2026 at 3:10pm
My D14 just started popping once or twice when I shut her off. I am brush hogging just like I always do this time of year. Brush Hogging going well...plenty of power and no hesitation when working. It DID stall twice this morning when I let the clutch out Ermmbefore she got warmed up. Thanks In Advance
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 03 Aug 2026 at 3:22pm
Let it idle for a bit. Is the idle set properly low enough?
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 03 Aug 2026 at 3:54pm
yep... if it is worked hard and REALLY HOT, they will try to diesel when shut off... get the low idle down, cool off for a minute, should do it.
BOH View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BOH Quote  Post ReplyReply Direct Link To This Post Posted: 03 Aug 2026 at 4:00pm
Thanks for the reply! I didn't let her idle tooo long, just enough to get all the load off the tractor check the gauges etc. I am cutting an old hayfield, so it ran without any real load, just came to the house about 1/4 mile. I wonder if I need to richen the mixture a bit maybe on the idle side.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 04 Aug 2026 at 4:53pm
Both of their replies are correct. Richening the mixture will only make it worse. I always do a cool down idle for at least a minute before shutting any of my tractors down. 2 minutes for my diesels.
Ed (Ont) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ed (Ont) Quote  Post ReplyReply Direct Link To This Post Posted: 04 Aug 2026 at 4:57pm
Make sure your timing is correct. And yes let it idle a bit. If all else fails shut if off in high gear and let clutch out a bit.
