CA Motor to D10
Gary Burnett View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Burnett Quote  Post ReplyReply Direct Link To This Post Topic: CA Motor to D10
    Posted: 10 Jul 2026 at 7:27am
Have a D10 that needs a motor and a CA with a busted rear with a good motor.Anything special I need to know mating the CA motor to the D10 rear?
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jul 2026 at 7:59am
Use the flywheel/clutch for the tractor. Some D10/12 tractors have 5/8" bolt for the front support but if your has 1/2" it will bolt up without a problem. The CA thermostat housing will line up with the D10/12 radiator, but the temperature gauge will interfere with the hood.
dfwallis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dfwallis Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jul 2026 at 12:35pm
Lose 5 or 6 hp vs stock d10 unless rebuilt with an overbore kit?
1952 CA13092, CA Pickup Plow, CA Cultivator, CA Two Row Planter, Dunham-Lehr GC78 Disc, Grader Blade, 3pt Fm180 Finish Mower
Bill Deppe/AC Salvag View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill Deppe/AC Salvag Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jul 2026 at 2:37pm
CA engine doesn't have the opening for a pump under the distributor
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jul 2026 at 2:47pm
If the tractor doesn't need the engine driven pump, that's not a problem. Gary just want to take two non usable tractors and make one that will work.
