rust remover on tools,,,,?
desertjoe View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote desertjoe Quote  Post ReplyReply Direct Link To This Post Topic: rust remover on tools,,,,?
    Posted: 14 Jun 2026 at 6:07pm
 Howdy,,,,what do others use to remove rust off your tools? This is mostly surface rust from lack of use,,,, I've tried WD40, (no help  Chemtool,( also no help)  ,,,ordered some no name stuff from Amazon,,also useless and had to return it.
 I saw some stuff on TV that looked mighty good,,,just spray it on ,,wait a couple of minutes and just wash it off with water,,,,sounds like bogus advertisment,,,,,?
 Any help???
Edited by desertjoe - 14 Jun 2026 at 6:09pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hubert (Ga)engine7 Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jun 2026 at 6:53pm
Vinegar will remove light surface rust but rinse it off then use baking soda solution and rinse again then dry and lightly oil. 3 in 1 oil works better than most. Z
AveryD12 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AveryD12 Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jun 2026 at 7:43pm
If they get too bad I use a wire brush to clean them up and coat with a mixture of 2 parts WD40 and 1 part 0w20 synthetic oil. I buy WD40 in 1 gallon can and mix for this purpose. Put mixture in a spray bottle….WD40 sells one of these also…it makes a good penetrating oil for most applications.
Clay View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Clay Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jun 2026 at 2:02pm
I have had good luck with EVAPO-Rust.
 Removes rust but do not use on phosphate coated tools or guns.
