D-17 Series 4 Hydraulic Pump Leak
knotle View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote knotle Quote  Post ReplyReply Direct Link To This Post Topic: D-17 Series 4 Hydraulic Pump Leak
    Posted: 03 Jun 2026 at 12:15pm
Have a leak at front hose. Leak is where hex head screws into pump housing. Is there an o-ring behind there that could be replaced? Thanks for any info.
Alvin M View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alvin M Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jun 2026 at 2:17pm
Yes O Ring
Post Options Post Options   Thanks (0) Thanks(0)   Quote knotle Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jun 2026 at 2:45pm
Thanks. Thought that might be the case. Would you happen to know the o-ring size?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jun 2026 at 3:07pm
it is a standard O-Ring Boss (ORB) to roll on that fitting. It also must be of a hardness to withstand 2400 PSI of pressure. A cheap hardware store Oring will generally be too soft and blow out quickly. Take the fitting to ANY farm implement dealership and they can fix you up. It is not metric.
Post Options Post Options   Thanks (0) Thanks(0)   Quote knotle Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jun 2026 at 5:54pm
Thanks for your help.
