Armature
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Topic: Armature
    Posted: 02 Apr 2023 at 1:56pm
Hi
Came across a used armature put back in box lol. 231347. The splines are stripped where it drives power steering pump. Before I toss it wanted to check that there’s no use for it.
Thanks
DaveKamp View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveKamp Quote  Post ReplyReply Direct Link To This Post Posted: 04 Apr 2023 at 9:24pm
If the armature is otherwise good, putting splines back on isn't impossible...  and if it's a common armature, the end can be turned to fit either a splined sleeve, or a standard belt sheave.  Is the armature used on any other application?  How easy is a good replacement to find?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 05 Apr 2023 at 4:51pm
First you need to find out what unit it fits. Could be a Delco long shaft for an 1100440/441 or 424 Diesel Gennie. If so, new Arms are available for those particular units. As Dave mentioned, those long shaft splines can be reground as long as the shaft isn't bent. I've seen where if the pumps seize, it could bend the mainshaft....  HTH
Steve@B&B
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 05 Apr 2023 at 10:35pm
Top of parts book it says deco-Remy #1100345.
Well it’s in the junk pile under bench if anyone wants it
