D262 head thickness
Wes (VA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Wes (VA) Quote  Post ReplyReply Direct Link To This Post Topic: D262 head thickness
    Posted: 06 Feb 2023 at 8:30pm
Looking to put this engine together that I acquired that came out of a D17.  Looking at the head before I take it to a shop.  Seems it is warped (my straight edge may not have been the straightest)  took about .008 of feeler to grab the edge.  It was high around cyls 3&4.  Again, my straight edge here at the house was a carpenters square.  Measured the distance between injector bores and head gasket surface was .162 (#6 inj) and the rest were .170-.173.  Can it be milled any more without getting too thin?
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 06 Feb 2023 at 9:14pm
They won't take that much off. Just to where the gasket surface cleans.
If they go that much, your going to have piston and valve clearance problems.                                   MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote Wes (VA) Quote  Post ReplyReply Direct Link To This Post Posted: 07 Feb 2023 at 8:06am
Ok thanks Mack, this will get that set of fire rings I bought from you.  Will probably be calling you for another set.
